RV.Net Open Roads Forum: Backing a DP up a steep slope.
 > Backing a DP up a steep slope.
vacuumbed
Salt Lake City, Utah
Posted: 01/24/12 10:55am Link  |  Print  |  Notify Moderator
I think that's fairly close, my driveway is steep.
Dale.Traveling
Newport News, VA
Posted: 01/24/12 10:59am Link  |  Print  |  Notify Moderator
vacuumbed wrote:
If it doesn't clear the approach would steel casters be the answer?
Depends. The casters will stop the hitch from scraping but will also lift the rear end. Lift it enough and you'll lift the drive wheels off the ground. You also run into the problem of dragging the front end and the axle starts to make the transition.
If the coach has an air leveling system consider inflating it to the maximum to get the house higher off the suspensions and give you more room. Drag the back end enough and you may get hung up and will need to be pulled off. Go slow, use a helper and working of communications before you start the test run.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
lanerd
Newport, OR
Posted: 01/24/12 11:11am Link  |  Print  |  Notify Moderator
wny_pat wrote:
15 degrees??? That is pretty steep!! Are you sure? If the ground raises one foot in three feet of length then you are close. That is 66 feet higher that the road level by the time you get up there.
The OP said 15% not 15 degrees! As Cargeo said... big difference.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
vacuumbed
Posted: 01/24/12 11:21am Link  |  Print  |  Notify Moderator
I was told that on this 96 Monaco it cannot be raised above normal ride height. I think it requires some expensive air suspension modification.
two-niner
las vegas, nv
Posted: 01/24/12 11:24am Link  |  Print  |  Notify Moderator
Well..Is it fifteen degrees or fifteen per cent??
Inquiring minds want to know.
vacuumbed
Posted: 01/24/12 11:43am Link  |  Print  |  Notify Moderator
15%, not degrees.
wolfe10
Posted: 01/24/12 02:48pm Link  |  Print  |  Notify Moderator
NOT a good idea. Very few frames were designed to accept a substantial load to the hitch area. Figure it was designed to handle rated tongue weight with a reasonable safety margin. But, that is a far cry from lifting much of the weight of the rear of the coach!
Plus, it will stick down further, reducing clearance even more.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
hohenwald48
Hohenwald, TN
Posted: 01/24/12 02:49pm Link  |  Print  |  Notify Moderator
Read the first post and you will clearly see it says 15% not 15 degrees.
2008 Fleetwood Jamboree 25G
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
michahicks
Waterford/Gaylord, Mi
Posted: 01/24/12 06:09pm Link  |  Print  |  Notify Moderator
Um, no. They'll just minimize the damage if it drags. Usually they actually decrease available clearance. If they don't break off or dig in (normal), they may even lift the rear of the coach high enough to remove traction from the drive axle.
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
vacuumbed
Posted: 01/24/12 06:24pm Link  |  Print  |  Notify Moderator
SacsTC wrote:
Check with Jim or Scott at Source1. They were talking about making up a kit for this purpose when I was there last Sept. Don't know if they actually did it or not. I had to do it to mine for my driveway.
The above post from a different thread is the answer I think. I called Scott this morning and he said he could put together a kit for me for about $250-$300. This is to raise the air suspension temporarily above normal ride height to clear the approach. He was very helpful.
