RV.Net Open Roads Forum: Backing a DP up a steep slope.
 > Backing a DP up a steep slope.
vacuumbed
Salt Lake City, Utah
Posted: 01/24/12 12:41am Link  |  Print  |  Notify Moderator
Just wondering about your thoughts on this.
I'm considering buying a 1996 Monaco Executive 40' Cummins M11 with an Allison 4060.
Will it hurt the coach to back it up a 15% slope for about 200 feet?
squeakkos
parker az
Posted: 01/24/12 02:11am Link  |  Print  |  Notify Moderator
no have done it many times. also you will love the m11 lots of power.
jetboater454
Camping or home
Posted: 01/24/12 03:22am Link  |  Print  |  Notify Moderator
Worst problem will be at the dishes sliding to the front.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
sch911
Rochester Hills, MI
Posted: 01/24/12 06:21am Link  |  Print  |  Notify Moderator
As long as you can clear the rear approach angle you should be fine. Those rear overhangs are sometimes long....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
2chiefsRus
USA Somewhere
Posted: 01/24/12 06:48am Link  |  Print  |  Notify Moderator
That's what I was thinking too.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Works2RV
Summerville, SC, USA
Posted: 01/24/12 06:55am Link  |  Print  |  Notify Moderator
Boy, this brought back some memories ----
First - to OP - as has been said, should not be a problem once you clear the transition.
Memory -- In the OLD days - used to have to back up hills that the forward gears just could not pull ( old trucks on the ranch ).
1987 36' Beaver Marquis High Tech Wide body
3208T CAT, MT643 Allison in a Gillig MHA
Koni's & Toyo all around
FMCA, Good Sam
Jetta TDI
Marsha & Buck
Ivylog
Blairsville, Ga. USA
Posted: 01/24/12 08:09am Link  |  Print  |  Notify Moderator
The Allison 4060 has a higher ration in reverse (4.8) than in first (3.5) so it will have more power backing up than going forward.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
vacuumbed
Posted: 01/24/12 10:14am Link  |  Print  |  Notify Moderator
If it doesn't clear the approach would steel casters be the answer?
wny_pat
Western NYS
Posted: 01/24/12 10:27am Link  |  Print  |  Notify Moderator
15 degrees??? That is pretty steep!! Are you sure? If the ground raises one foot in three feet of length then you are close. That is 66 feet higher that the road level by the time you get up there.
CarlGeo
Central San Joaquin Valley, CA
Posted: 01/24/12 10:42am Link  |  Print  |  Notify Moderator
Grade at 15% will rise 15 ft in 100 ft horizontal. Your example is about 30% grade or double the OP's stated grade.
CarlGeo
