RV.Net Open Roads Forum: Tech Issues: Converter Inverter 2007 Damon Daybreak
 > Converter Inverter 2007 Damon Daybreak
Rqse7
Tularosa New Mexico
Posted: 01/24/12 06:41pm Link  |  Print  |  Notify Moderator
I am trying to help a friend.
He has a 2007 Damon Daybreak. Gas rig with a gas generator. It has a converter at the driver's side rear. I do not see an inverter. The TV and VCR will not work unless he starts the generator, or plugs into shore power.
Is it possible that this 2007 rig does not have an inverter? The converter is an Inteli Power 9100.
I would think a 2007 would have an converter/inverter combination. Am I missing something?
Thanks in advance!
mena661
Posted: 01/24/12 06:43pm Link  |  Print  |  Notify Moderator
Quite a few gas motorhomes DO NOT have inverters. It's usually optional.
Trojan L16 6V's 740 Amp-hours
KJINTF
Montana
Posted: 01/24/12 06:45pm Link  |  Print  |  Notify Moderator
Yes indeed it is possible to NOT have a inverter installed from the factory
Thompson Falls Electronics
Always more projects than time
pianotuna
Regina, SK, Canada
Posted: 01/24/12 06:58pm Link  |  Print  |  Notify Moderator
Hi,
And not having one from the factory is probably a good thing. This way your friend can get one tailor made to his needs.
If it is TV then the 300 watt unit from Morningstar is just wonderful.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
sch911
Rochester Hills, MI
It's highly unlikely that it has one. It definitely wasn't standard on those models. Not even today on many gassers.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
MauryFrench
Manvel, TX
Posted: 01/24/12 07:51pm Link  |  Print  |  Notify Moderator
Okay I am lost. Is the TV AC or DC? If you are running on batteries I cannot even imagine inverting DC to AC to watch an AC TV. What am I missing?
Maury French
1990 Hitchhiker II 26 ft 5th Wheel.
michelb
Ottawa, ON, Canada
Posted: 01/25/12 07:52am Link  |  Print  |  Notify Moderator
Some smaller TVs in motor homes (13" and less) are DC or AC/DC but the vast majority of them are just regular household AC TVs.
As far as inverting DC to AC to watch TV, that's what everyone else does if they want to watch TV without 120V (we camp several weeks every summer without hookups and it doesn't affect our TV usage).
As far as the OPs question, your Daybreak is very unlikely to have come with an inverter. Even on the 2012, it's only available as an option on one of their floorplans when you get the outdoor entertainment center (not available at all on the other floorplans).
* This post was edited 01/25/12 08:07am by michelb *
ryanallie1
Magalia, Calif
Posted: 01/25/12 08:39am Link  |  Print  |  Notify Moderator
Hi All.
Well, now you have learned something. We don't have a Built-In Inverter either in our Motorhome. We really haven't found a need to install a Hard-Wired Inverter into our Motorhome. But we can tell you this. That is what small Inverters are for. Most people who don't have a Built-In Inverter use a small Inverter to watch TV or to run other small items when they don't have shore power or want to run thier generators. We have several different sizes, and one Pure Sine Wave Inverter also. They come in real handy if you are a Boondocker. And if you don't want to go to the expense of buying an Inverter and Hard Wiring it in, then the smaller portaable Inverters is the way to go. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
MauryFrench
Manvel, TX
Posted: 01/25/12 08:53am Link  |  Print  |  Notify Moderator
I am just amazed you can run an AC TV off of inverted power from a battery for any length of time. But then, I am not an electrician and I am only learning about long term RV usage.
Thanks all.
Alpenliter
Fulltimer: Wherever we are!
Posted: 01/25/12 09:04am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Although my rig does have a 2000 watt inverter, I've used it twice. The Morningstar 300 handles all our daily needs quite nicely. Terrific product and uses hardly any power.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
