I have torn down some rotten ceiling and insulation and repaired some holes in the roof of the trailer. I have survived a few wicked rainstorms so I am ready to put ceiling back up. Previously there was the pink fiberglass insulation between the ceiling and the roof.
My question is, should I go back in with the "puffy" fiberglass insulation or can I get by with the insulpink Installation boards?
As I type I pretty much think I should go with the regular insulation as I can tuck it up into the rafters, but wanted to get some other opinions.
I can't say which is best but mine has styrofoam insulation. I think styrofoam panels along with expandable foam to fill in the cracks and spaces would be the best.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Interesting concept. AND, I can get pretty much all the styrofoam I want where I work for free. I will have to cut to size but that free word sure does ring true!
tenbear wrote: I can't say which is best but mine has styrofoam insulation. I think styrofoam panels along with expandable foam to fill in the cracks and spaces would be the best.
Check the R rating. I was looking at putting different types of insulating blocks on the inside of my garage door. The fiberglass had a higher R value than any of the styrofoam
Enjoying Your Freedom?
Thank A Veteran
Native Texan
I installed insulation many, many years ago. At that time, the fiberglass stuff would way outdo any kind of board. Check the R values. I think styrofoam will be way less. And you will have to deal with all the cracks and edges in getting an air tight seal.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel-for sale now that we are not full-timing
2011 Keystone 23rks Hideout to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
Despite what many might think, the Air Pockets in the insulation, are what give you a R-Value.
So, loose "batting" will give you much better insulation than "Pink", or "Blue" styrofoam............for what we want.
Naturally, don't Pack it in, gently push to fill the air space, and trim any excess..............IE, 3" space, but 4" insulation avail............don't Shove it all in, trim off that extra inch, then put up your wall (or ceiling).................it needs the "Space". ...to work.
That is why most all units have " fluffy " insulation in roofs, and sidewalls.
2000 Ford SuperDuty F-350 Powerstroke,Dually..The Tow Monster
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR temp,Garmin 1300 /GPS
Doran Pressure Pro
VU Qube Satelite Rally's attended so far-16 My Blog
Good Sam Member
bfast54 wrote: Despite what many might think, the Air Pockets in the insulation, are what give you a R-Value.
Follow this advice. This is how it should be installed.
