RV.Net Open Roads Forum: How to winterize a black water flush system
 > How to winterize a black water flush system
Cimriver
Colorado
Posted: 01/24/12 09:24pm Link  |  Print  |  Notify Moderator
Last spring when we had the fifth-wheel out for the first time, the check valve in my black water flushing system had a leak. That's when I figured out that I had totally forgotten to winterize this system. I would be interested in knowing how others winterize their systems. I had my rig professionally winterized last fall, but would have always done my own winterizing and would like to in the future.
Gordon & Patti
2008 F-350, 6.4L. Power Stroke, CrewCab
2012 Dutchmen Komfort 3130FRL Fifth-Wheel
Be Safe!!!!!
Gadget Guy
Calgary
Posted: 01/24/12 09:26pm Link  |  Print  |  Notify Moderator
Blow it out with air.
JayWalker2009
I'm not really a
Posted: 01/24/12 09:35pm Link  |  Print  |  Notify Moderator
I don't do anything with mine except empty it, then put some pink stuff in it afterwards.
Plastic will bust or crack when the ice causes it to expand. A very large tank with a tiny bit of water left in it (as in whatever residual water is left behind after a good emptying) will usually be fine. In your smaller pipes that it expands and the pressure will cause it to burst. I put some RV antifreeze in my black and gray tank after emptying completely, not even a lot of it, for safe measure. Never a problem in ten years.
Cimriver
Colorado
Posted: 01/24/12 09:38pm Link  |  Print  |  Notify Moderator
Plastic freezes when the ice causes it to expand and contract. A very large tank with a tiny bit of water left in it will usually be fine. I put some RV antifreeze in mine, not even a lot, for safe measure. Never a problem in ten years.
Not worried about the tank, but the line and check valve in the black water flush.
JayWalker2009
I'm not really a
Posted: 01/24/12 09:39pm Link  |  Print  |  Notify Moderator
All i have ever done is put in RV antifreeze after draining everything, and in all the water traps. About five years ago I used to also blow it out with an air compressor, I stopped doing that and its been fine. And we've had some pretty good freezes.
old guy
Oregon (pronounced Or e gun)
Posted: 01/24/12 11:31pm Link  |  Print  |  Notify Moderator
I blow mine out with air, same time I blow out the rest of the TT
webslave
Clearville, PA
Posted: 01/25/12 04:31pm Link  |  Print  |  Notify Moderator
X2
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
beemerphile1
I'm 57, I'm not a
Posted: 01/25/12 04:36pm Link  |  Print  |  Notify Moderator
webslave wrote:
X2
X3
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
Chuck&Gail
In the Colorado Mountains
Posted: 01/25/12 05:26pm Link  |  Print  |  Notify Moderator
x4. And after I blow it out I pour antifreeze in it.
I winterize all other lines with antifreeze, only blow out black tank flusher.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
rock077
PA
Posted: 01/25/12 06:21pm Link  |  Print  |  Notify Moderator
I have an outside faucet with hose. I connect the hose to the flush input and pump in the antifreeze.
* This post was edited 01/25/12 06:29pm by rock077 *
2009 Colorado 30CE
2006 Dodge Ram 2500 Quad Cab CTD 4X4
PUP 4 seasons, HTT 4 seasons, Fiver 3 seasons...
