RV.Net Open Roads Forum: Technology Corner: Firefox Bookmarks
 > Firefox Bookmarks
Little Kopit
TheMaritimes.ca
Posted: 01/25/12 02:43pm Link  |  Print  |  Notify Moderator
Somehow or another, I've deleted my most used category in my Firefox Bookmarks.
Is there anyway I can recover it?
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
Dutch_12078
Great Sacandaga Lake, NY
Posted: 01/25/12 03:25pm Link  |  Print  |  Notify Moderator
Click on "Bookmarks" on the menu bar, and then select "Show All Bookmarks". In the new window that opens, click on "Import and Backup" on the menu bar, and select "Restore". Pick a date that's before the entries were deleted, and confirm the selection.
If you do not see the "Menu Bar" (File, Edit, View, History, Bookmarks...) at the top of the Firefox window, right click in a clear area of the address bar and check the "Menu Bar" entry in the drop down list.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Little Kopit
TheMaritimes.ca
Posted: 01/25/12 03:43pm Link  |  Print  |  Notify Moderator
Dutch and Norm,
Mission accomplished.
If they had put that "Import and Backup" as a sub-topic under the "Show all bookmarks" outline topic, I would have seen it.
Nice to learn something that easily.
I think that the two topics in 'recently added' are the only ones I will have to hunt for now.
Little Kopit
TheMaritimes.ca
Posted: 04/20/12 11:47am Link  |  Print  |  Notify Moderator
It's happened to me again.
& under import and back up, restore has 10 dates. When I click on them, I get "unable to process request"
& there is nothing in back up.
BTW, when I came up against the problem, I shut everything down and then did a system restore.
wittmeba
Virginia
Posted: 04/20/12 02:16pm Link  |  Print  |  Notify Moderator
Try selecting the oldest date first...if that fails, try this.
See if you can export them (same process but select "Export to HTML file") to an HTML file. If so, you can likely rebuild the HTML file and fix error(s) that may be keeping the file from loading.
Go thru the process and watch where the HTML file gets saved - may be your desktop or another directory.
Tell us how big the file is and Ill suggest some options to restore.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
Clay L
Sioux Falls, South Dakota
Posted: 04/20/12 02:28pm Link  |  Print  |  Notify Moderator
I use MozBackup to back up Firefox favorites and settings along with Thunderbird emails, folders, settings.
You can download it HERE
I also use Microsoft's Synctoy2.1 to back up my Desktop and my data files along with the Firefox and Thunderbird profiles that Mozbackup backs up so I end up with a double backup of FF and TB.
you can download it HERE
The FF profile is in: C:\Users\YourName\AppData\Roaming\Mozilla\Firefox\Profiles\xxxxxxx.default
The TB profile is in C:\Users\YourName\AppData\Roaming\Thunderbird\Profiles\xxxxxxxx.default
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
wittmeba
Virginia
Posted: 04/20/12 04:17pm Link  |  Print  |  Notify Moderator
Clay is right but you wont see the directories by navigating with MyComputer or Explorer - they are hidden.
Most simple way to get to the "current" logged in profile is enter about:support in the URL line. Under Application Basics, click "Show Folder". This should put you into the profile or Roaming and you can then navigate. You may need to navigate up 1 directory level.
The other way is in the Start/Run box enter "%appdata%" without the quotes. This will do the same.
It would be a wise idea to locate your bookmarks folder and save some of these files to another directory like C:\Temp or something similar.
Little Kopit
TheMaritimes.ca
Posted: 04/21/12 12:08pm Link  |  Print  |  Notify Moderator
Ok, I've found the profile and the Bookmarks Back up folder.
Date - there are 10 files.
"JSON File
137 KB
But the other thing is something is keeping me from putting in any new bookmarks. I've tried to follow some of their how tos and and they lose me.
Also I might mention on one run of Malawarebytes, I had two bad files
I've tried setting up Opera. Slower than Moses snail and then some. & of course, no adbloc.
kirbybear
Ft. Lauderdale Fl USA
Posted: 04/22/12 09:30am Link  |  Print  |  Notify Moderator
Same topic different problem. New computer, Win 7, Firefox 11. The "Bookmark this page" , " choice " function to get the correct folder does not work. The older computer with FF 10 did work.
I was unable to find a solution in FF help.
Any one experience the same problem? Bob
SCClockDr
SC UpState
Posted: 04/22/12 11:11am Link  |  Print  |  Notify Moderator
Just tested FF 12 all works OK here. Do both the "choose" menu option & the "\/" button above the blue "i" fail?
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, PD 9260 Upgrade, 2 Gal Accum., WiFiRanger GO/Mobile/SKY
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart, Cobra (19).
USN Ret
 > Firefox Bookmarks
