RV.Net Open Roads Forum: Shurflo Smart Sensor 5.7 vs Revolution 4008 pumps
 > Shurflo Smart Sensor 5.7 vs Revolution 4008 pumps
Sailbad
Bernardo, New Mexico or Quartzsite
Posted: 03/18/12 12:26pm Link  |  Print  |  Notify Moderator
Well, I know this is sort of an old topic but I've lost 2 shurflo 5.7 pumps in less than 48 hours..
Has anyone found another pump that I can use for replacement?
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
Keep Your Powder Dry....This Ain't Gonna Be Fun
Livin Good
On The Road
Posted: 03/18/12 04:25pm Link  |  Print  |  Notify Moderator
My Shureflow 5.7 has been running great for 7 years. Plenty of water(no difference when another faucet is turned on) and so quiet we never hear it come on. My understanding that many problems are related to low voltage and leaky lines.
lyle_47250
madison indiana usa
Posted: 03/18/12 05:35pm Link  |  Print  |  Notify Moderator
Mine has been seamless for 6 years, whats not to like?
Lyle & Ginger and the 82 Revcon
gordonls
Victoria, Texas
Posted: 03/18/12 08:21pm Link  |  Print  |  Notify Moderator
After replacing 5 pumps, I replaced my Sure flow with a Aquatec Aguajet RV 5503 has worked with no problems for the last year.
2007 Monaco Diplomat PDQ
40' 400HP Cummins
2012 Buick Enclave Toad
FMCA F376075
liborko
Surrey, B.C.
Posted: 03/18/12 10:01pm Link  |  Print  |  Notify Moderator
My 5.7 was cycling since new. Recently I tried new valve body and it was worse than the original. So I ordered a different pump as I stated in my previous posts. Before throwing the old pump away, I decided to try to fix it.
The valve body has 10 valves. The possibility that one of these valves will develop leak is fairly high. So I decided to give all of these valves good cleaning. I used isopropyl alcohol soaked q-tips and paper towel. Alcohol swabs would work also. Spent more than an hour wiping and wiping until no black residue showed on q-tips. After reassembling the pump the pump works fine. So I did not install new pump for now and keep it as spare.
The 5.7 Shurflo is a good pump when it works. I think better material like Viton should be used to make valves instead of the EPDM. It seems that oxidized EPDM residue on valves and valve seats causes poor seal and causes pump cycling. The pump does not have a separate check valve.
* This post was edited 03/18/12 10:16pm by liborko *
