RV.Net Open Roads Forum: Tech Issues: Awning repair.
 > Awning repair.
Francesca Knowles
Port Hadlock, Washington
Posted: 01/27/12 01:22am Link  |  Print  |  Notify Moderator
Another vote for cutting off the rotted end of the awning, provided the rest of it's in good shape.
I've done this, too- the part that's ruined is usually just the single wrap that's constantly exposed to the sun.
I managed to do it without taking the whole thing apart- I cut it away (canopy relaxed), removed the trash part, stitched in a spline sleeve and pushed that part into the channel.
THEN I pushed the holding spline through the sleeve in the channel, using a bit of graphite for lubrication.
The hardest part was making sure that the fabric was nice and square before stitching.
* This post was edited 01/27/12 11:50am by Francesca Knowles *
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
dougrainer
Carrolton, Texas
Posted: 01/27/12 06:18am Link  |  Print  |  Notify Moderator
If the awning is more than 10 years old, that means it is dried/weather cracked. You can try to repair but it will continue to deteriorate and crack and seperate. It is always best to install new fabric on this type problem. Doug
CampersX4
Oceanside, Ca
Posted: 01/27/12 06:36am Link  |  Print  |  Notify Moderator
I never thought about removing the rotted part completely. I might have to give that a try.
Thanks for the replies.
 > Awning repair.
