olly72
Pembroke pines, fl
Hi All: I just bought a digital tire gauge. When I take readings from the tires the digital reads about 3-4lbs. less then my stick and numbers gauges. Whic one should I believe. I don't want to over fill the tires.
Thanks Russ
2008 Itasca Sunrise 32H
Brake Buddy
2005 Chevy Malibu toad
tank7234@comcast.net
downtheroad
Pacific Northwest
I have a drawer full of tire gauges and they all read differently by a pound or two..(I guess I have a bunch of cheap gauges)
Anyway, I just pick one and use that one and only that one. Close enough.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Just Bob
SD/CT/FL/WY
Take both to your tire dealer and they will calibrate them to match theirs.
alphamale11
Greenville SC
i had to stop the technician from filling my tires yesterday...had asked that they check them as part of maintainence, as my stick showed them a little low at 85lbs.. He started filling and then commented that I only had 60 lbs. in my rears which struck me as odd, and asked him to get another gauge. Sure 'nuff, they were actually at 85 lbs.!! Could have been a dangerous situation if they'd had another 20 lbs. put in them. Bottom line is that gauges are notoriously inaccurate to some degree. I feel most comfortable with my old stick..
Capt Rick
Key Largo, Florida
Stick gauges can give faulty readings depending on their quality and how they are kept. I bought a digital gauge for about $50. at NAPA. Supposed to be accurate to +or - 1 lb.
I only check the tires in the morning when cold. If I check them in the afternoon there will be a 5 lb difference between the sunny side and the shady side!
Capt. Rick and JoAnn
Key Largo, Florida
nelson
Clio,Mi USA
There are gauges and then there are good gauges.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
powderman426
ohio
I remember from the good old days that most all the service stations and truckers used Milton gauges so thats what I still use today. I suppose you could take it in and get it tested against a known source, but I think Ill just use it as is.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Weathertodd221
FL
a decent shop will have a calibration guage you can measure yours against.
Or you can google how to make one with $20 worth of material.
Rule of thumb for accuracy tends to be in the middle of the gauge range.
If your tires need ~100 psi... best to have a gauge that reads to 150+.
Noel
Southern Oregon
I ordered, but not yet received, a 0-150# digital tire gauge for $26.90, shipping included from www.getagauge.com. It was the DT150. Mfr. is G.H. Meiser & Co.
Noel
2003 National Dolphin LX 6335, W22, 8.1L
Nomadac
Columbus, IN
I bought this gauge http://www.campingworld.com/shopping/item/tire-pressure-gauge/25770 that I have used for years. I had it checked and verified for accuracy last year when I replaced my Michelin tires at a Truck Tire store. They have a gauge to check the accuracy on all of their tire gauges.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
