acudr
San Diego
I took a video of loading our camper for our last trip. Finally got to editing!
I'm still a bit new at this video thing, but i think this could be useful for someone just starting. It's about 6 min.
Loading a Truck Camper
Bertram
bill harr
California
WOW you have lots of room in your truck bed. At first I could not beleve the amount you turned the front wheels. My 2005 Tundra has 1/2" on each side when I back under my 4WC Hawk, centering is not a problem.
Pete_k
Stantonville Tn
Man wish I had that much room. When mine starts in the bed you have to be lined up. Not enough room to move the front end like that. Even between the top of the bed and the camper I can't hook my Electric cord up if I back all the way up.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
nycsteve
NY
Good video! I also have much less room. I have 3/4" clearance on both sides of the tailgate opening. I have to be dead on center from the start. I like the loop you use to hold the wire harness out of the way when loading. Thanks.
acudr
San Diego
You guys must be masters at loading your truck! Here I thought I was tight!
Do you have any suggestions for noobee's ?
Boatycall
Tacoma, WA
OHHH!!!
That explains why I can't open the door!
You're supposed to load it BUNK FIRST!!
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
bobndot
NY
B......
So that was you on Schuster Pkwy . We Thought you were driving in reverse .
acudr
San Diego
Boatycall wrote: OHHH!!!
LMAO!
tilemantim
Santa Rosa,Ca
I too cannot turn my wheels like that. If I'm off an inch I ether drag the saddle tank down the bed rail or rub the wheel well on the other side. If I'm not dead nuts on I have to pull back out and re-align.
DianneOK
Donnelly, ID
We, also, have less than an inch on either side. I try to line up as close to square as I can with very little wheel turning. Terry spots, as I am too short (only on one end, tho) to see into the bed. It usually takes less than 20 minutes start to finish.
Dianne (and Terry) (Fulltimed for 9 years)
Donnelly, ID
HAM WB6N (Terry)
2012 Ford F350, diesel, 4x4 SRW, crew cab, longbed
2009 Lance 971 Truck Camper, loaded
Life Member Good Sam
Geocache..."RVcachers"
RV net Blog
Camping, nature's way to feed the mosquitoes
