RV.Net Open Roads Forum: Truck Campers: How to load a Truck Camper video
 > How to load a Truck Camper video
nstate
usa
Posted: 01/31/12 07:11pm Link  |  Print  |  Notify Moderator
That was funnier than hell!!!!!!!!!
Boatycall wrote:
OHHH!!!
That explains why I can't open the door!
You're supposed to load it BUNK FIRST!!
Camper_Jeff_&_Kelli
Seattle
Posted: 01/31/12 09:20pm Link  |  Print  |  Notify Moderator
Boatycall, that TC back door behind the cab window should have been your first clue that Houston had a problem.
We've all had one of those days where no matter what you do, that sucker ain't gonna line up with the truck. I had an episode where we were trying to get out of Dodge after work and for the life of me, I could not line up with the camper. It took about ten tries of backing in and driving out. Shifting this way, shifting that. I finally got the two mated after about ten tries but what an ordeal. Being twilight didn't help the situation either but we got off to a late running start for a three day escape.
I'm sure it will be useful to new folks trying to get the swing of things.
J&K
Camper Jeff and Kelli's Blog!
Gripnriprod
Alaska
Posted: 02/01/12 07:52pm Link  |  Print  |  Notify Moderator
Boatycall wrote:
OHHH!!!
LOL
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
Photog101
Garden City, Michigan
Posted: 02/01/12 08:45pm Link  |  Print  |  Notify Moderator
I wish that I had as much room as the video. My dually has 3/4" on either side inside the box between the wheel wells and the camper. If I am not correctly aligned and square, it ain't going in.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
acudr
San Diego
Posted: 02/01/12 10:09pm Link  |  Print  |  Notify Moderator
And here I thought I had it so hard!
Bertram
tri5ron
Orange County Ca. USA
Posted: 02/02/12 04:29am Link  |  Print  |  Notify Moderator
Hahahahaha !!!
come on up to OC, and I'll let you give it a try with my 11 1/2'er, and a Dually.
3/4" on either side, (jacks to dually fenders),and must be straight from at least 6' out." I've've got A TOTAL of 3/4" to set it right.
a pop-up on a swd would be a breeze !
LMAO !
acudr
San Diego
Posted: 02/02/12 08:40am Link  |  Print  |  Notify Moderator
tri5ron wrote:
Hahahahaha !!!
LMAO !
I can't imagine. You ALL must do all your setup before you back under the camper. Where I can maneuver beneath the camper, you must be perfectly set up before. Meaning the truck must be straight, without references.
Are there any TIPS for noobies about how to get your trucks aligned?
Somebody needs to make a video!!!
b
mtnstarman
Piney Woods
Posted: 02/02/12 01:57pm Link  |  Print  |  Notify Moderator
Wouldn't it be nice if you could lay down a couple of steel I-beams just wide enough for your tires. Back in on these things and drop your TC. When backing in to load up again you would be lined up perfectly.
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 02/02/12 02:58pm Link  |  Print  |  Notify Moderator
Great job with the video.
Paul
mountainkowboy
Socal High Desert
Posted: 02/04/12 05:26pm Link  |  Print  |  Notify Moderator
My loading aid, as you can see, there aint much room from side to side. So you gotta be pretty close when you start backing under.
Chuck & Ruth with 4-legged Dixie & Hanna
90 F350 S/C Dually, Camper Pkg, 460/ZF 5spd, Banks Powerpack, Torklift Superhitch/32" extension.
94 Alpenlite 29RK DL
06 CRV
64 IH Scout 80
