RV.Net Open Roads Forum: Truck Campers: Happijac Camper Jacks
 > Happijac Camper Jacks
ogrer
Norwood On
Posted: 02/01/12 04:34am Link  |  Print  |  Notify Moderator
I have just gone through the rebuild of the jacks for my Bigfoot, with the Happijac factory's support.
Now, before I assemble the jacks, do I paint, powder coat or use bed liner?
Where I live, the local Rhino and LineX dealers do not recommend bed liner in white. They say set up and flushing is expensive, and that the white liner turns yellow with sun exposure.
So my next question would be, should they be painted black and sprayed white.
Hearing some one else's experience would help me make my mind up.
Bob
Bob & Jan
GregTheCampingGuy
Morgan Hill, CA
Posted: 02/01/12 08:14am Link  |  Print  |  Notify Moderator
I would powder coat them white. There is a lot of prep I would do to them first like rounding all of the edges. I see electric jack brackets and ladders that have a factory coating and the coating ALWAYS fails at the sharp edges.
Would you do it yourself or take them to a powder coating shop?
rabenfels
Colorado
Posted: 02/01/12 08:33am Link  |  Print  |  Notify Moderator
Just saw Brian Brawdy's Lance rig - he has the jacks coated with black LineX.
Mello Mike
Mesa, AZ
Posted: 02/01/12 08:47am Link  |  Print  |  Notify Moderator
Yep, I got pics of Brian's rig last week.
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
Heygrrl
So Cal
Posted: 02/01/12 09:40am Link  |  Print  |  Notify Moderator
Is coating ones happijacs for cosmetic purposes or does it serve some function?
moon
ms. moon
bedrocker
lompoc ca
Posted: 02/01/12 10:04am Link  |  Print  |  Notify Moderator
powercoat for year of enjoyment [emoticon]
DonCurley
La Sal, Utah
Posted: 02/01/12 02:05pm Link  |  Print  |  Notify Moderator
If you end up deciding to go with bed liner material, you need to revisit the Line-X approach. Standard white bed liner material can turn a bit pinkish after extended UV exposure. However, if you specify Line-X XTRA, you will easily solve this issue (and it is available in white). Line-X XTRA has UV protectants in the formulation to circumvent fading & color shifts, it offers better gloss retention, and with DuPont KEVLAR, it also provides superior protection against scratches, gouges, and punctures.
I went with Line-X XTRA in black for the bed in my 2007 Dodge Ram 3500, and it looks as new as the day it went in over four years ago.
Good luck with whatever you decide to go with for your jacks.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo MT's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
fast.5
Ontario, Canada
Posted: 02/01/12 03:32pm Link  |  Print  |  Notify Moderator
Hi Bob: Just keep changing campers like me.[emoticon][emoticon][emoticon]
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
NEOK
Oklahoma
Posted: 02/01/12 04:57pm Link  |  Print  |  Notify Moderator
I'm curious if you coat the extendable part of the jack legs with Line-X will they clear the fixed portion of the jack when you retract them? I have considered having my Happijacs coated with Line-X too.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
DonCurley
La Sal, Utah
Posted: 02/01/12 05:13pm Link  |  Print  |  Notify Moderator
If I was going to go the direction of having my jacks Line-X'ed, I would only do the outer tube and perhaps the exposed portion of the inner tube & foot that is exposed when the jacks are fully retracted. Happijacs have small "bearing pads" on the lower end of the external tubes which can and do rub on the outer surfaces of the internal tubes during extension and retraction. Over time, this would likely have the effect of scraping and perhaps rubbing off the Line-X coating. For the inner tubes, I would think that powder coating would be a better choice due to the harder and thinner coating involved.
