RV.Net Open Roads Forum: Class A Motorhomes: Steering Wheel Table
 > Steering Wheel Table
Scrapz
Posted: 02/02/12 02:38am Link  |  Print  |  Notify Moderator
I have a small round tabletop I want to use over our steering wheel as a table. The wheel can be adjusted to a level position. Does anyone know how much weight the steering column/wheel can hold? I was planning to put the portable ice maker on the table. I think the ice maker weighs about 50 lbs.
Kathy ">
Executive
Posted: 02/02/12 02:47am Link  |  Print  |  Notify Moderator
Kathy, you shouldn't have any problems. We have a lamp, a plant and several pictures on ours. They're pretty solid....Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
bluwtr49
Green Valley, AZ
Posted: 02/02/12 07:29am Link  |  Print  |  Notify Moderator
I assume this is for stationary use....not driving??
Kidding aside, I've been thinking about using the steering wheel for a computeer table, just haven't found one I can easily adapt.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
Scrapz
Posted: 02/02/12 08:54am Link  |  Print  |  Notify Moderator
Thanks, Dennis! DH would shoot me if one of my projects screwed up the steering.
The tabletop I want to use is from one of those particle board side tables with screw on legs. The flimsy legs disappeared a long time ago. I'm confident dh and I can find a good way to stabilize the top to hold the ice maker. This will be great for getting the ice maker out of the way. Now if I can just get DH to put an elec outlet in that area. ;-)
Dick, when I put ours into the table position it is pretty high. You might need a tall stool to reach your computer comfortably.
lanerd
Home in Ridgecrest CA for the winter.
Posted: 02/02/12 09:27am Link  |  Print  |  Notify Moderator
I don't think it would be a problem either. Of course lifting the 50 lb ice maker up that high could be a little difficult. Hope hubby is a big guy.
We purchased a 1/4 inch by 18 inch round acrylic (clear plastic) from JoAnn's (hobby store) and set it up there with a small table cloth covering it and all of the steering column. Then we set on top of that a really nice little table lamp, a small plant and a little basket for keys and such. Our coach has a 110v outlet just on the right side of the console and we plug the lamp into that. I've been thinking of putting another outlet on the left side of the console so that the lamp's cord is laying out in the open. Another project....another day.
Go for it, I say.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
DSDP Don
Moorpark, Ca
Posted: 02/02/12 06:35pm Link  |  Print  |  Notify Moderator
Scrapz...Your coach wheel should support what you want to do without an issue. Just one caution. Make sure you're not depressing the air horn bar when you put weight on the wheel. When you're aired down, your airhorn won't make any noise, but it will operate the horn and blow the fuse if the pressure is constant.
I had placed an object on the steering wheel one weekend and didn't realize it was depressing the horn bar. When I drove home, I realized the horn didn't work......I had blown the fuse.
Don & Mary
2014 Newmar Dutch Star 4018 - All Electric
Cummins 450ISL
2016 GMC Canyon 4WD Crew Cab
Executive
Posted: 02/02/12 09:21pm Link  |  Print  |  Notify Moderator
Oh! Yeah! Forgot about the warning about the air horn....DW has done that twice when setting up the inside. Not funny when you're on a ladder cleaning the bugs off the windshield....[emoticon]....we just wave to the neighbors like we meant to do it....[emoticon][emoticon]..@Kathy, those tables are great but make sure the metal leg assemblies don't press on the horn button. I left them on in order to keep the table from sliding off the steering wheel, but you have to watch their placement.....Dennis
Wherever I happen to park
Posted: 02/03/12 10:28am Link  |  Print  |  Notify Moderator
I do not know how much a steering wheel can hold but I know I put way more than 50 pounds of load on it when I get out of the driver's seat Way more.
Home is where I park it.
Boonedocks
Posted: 02/03/12 10:46am Link  |  Print  |  Notify Moderator
For anyone wanting to make a steering wheel table, I once was directed to a link for a DIY version. I have yet to make mine, but intend to follow these instructions.
DIY Steering Wheel Table
2003 Country Coach Intrigue towing 2006 Ford Focus. Follow our full timing adventures at The BooneDocks
