RV.Net Open Roads Forum: Tow Vehicles: Torque App Android
Search only in Tow Vehicles
 > Torque App Android
SeaRayder
Alabama
Posted: 02/22/12 06:37am Link  |  Print  |  Notify Moderator
jiveturkey692000 wrote:
I wonder how it would work on my 94.5 powerstroke. Have to do some research...
I don't think OBDII started till 1996 but I'm not 100% positive.
Current RV: 2009 Keystone Springdale 280FWIKSSR Fifth Wheel
Current TV: 2012 Ford F150 Heavy Duty Crew Cab EcoBoost Lariat 4x4
ib516
Up here!
Posted: 02/22/12 07:52am Link  |  Print  |  Notify Moderator
Correct.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 02/22/12 08:07am Link  |  Print  |  Notify Moderator
I found a hard wired unit that plugs into your OBDII port, then your phone via a USB cable. I wounder if this would give you a more accurate reading or (true time)?
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
jiveturkey692000
NE PA
Posted: 02/22/12 08:08am Link  |  Print  |  Notify Moderator
Yeah thats what I hear. Thanks .
Dan
96 Fleetwood Mallard, 30'
05 Ford F250 Super Duty 4X4 6.0 Powerstroke, CC, Lariat 8ft Bed "Redneck Cadillac"
82 Dodge Ram W350 4X4 Clubcab. 216,000 miles
OH48Lt
Whitehouse, OH
Posted: 02/22/12 08:21am Link  |  Print  |  Notify Moderator
Downloaded that app and plugged in a bluetooth OBDII adaptor. Seems to work pretty good on most items. Haven't been able to get true turbo boost readings in psi though, only get negative vacuum values when using the boost gauge on the app.
2011 Ford F-150 Lariat Crew Cab 4x4 EcoBoost -a 6 cylinder hemi stomper
2012 Harley Street Glide -ember red sunglo
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
SeaRayder
Alabama
Posted: 02/22/12 08:56am Link  |  Print  |  Notify Moderator
That can be fixed! From the home menu go to your settings then units. Check "Use PSI" and "Dont Display PSI as in/Hg" then go to your vehicle profile>Edit and set the boost adjustment to "0"
-SeaRayder
45Ricochet
North Idaho
Posted: 02/22/12 10:26am Link  |  Print  |  Notify Moderator
Thanks for the info, keep us posted if any glitches show up.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
elkhorn98
Santa Rosa, California
Posted: 03/30/12 12:08pm Link  |  Print  |  Notify Moderator
Will torque pro show egt for a lmm duramax?
Elkhorn98
2010 GMC Sierra 2500HD 4x4 Duramax/Allison w/45 gal Transfer Flow Tank
RBW X16 Slider, Yamaha EF 2400iS
2007 Springdale 245 5th Wheel - E-Z Flex HD Suspension & Mobile Outfitters Shock Kit Upgrades
with Firestone Transforce Ht Lt 2357515 C tires
SeaRayder
Alabama
Posted: 03/30/12 12:30pm Link  |  Print  |  Notify Moderator
depends on if it has a probe from the factory or not...
elkhorn98
Posted: 03/30/12 12:57pm Link  |  Print  |  Notify Moderator
Anyone know if the lmm duramax has the egt probe stock?
