jeff14
St. Louis, Mo.
Should I being carring an extra fuel filter for my diesel tow vehicle?
PapPappy
Wilmington, NC
Well, unless you believe you can buy one at any corner or mile marker on the highway, I'd keep one with me. What's it gonna cost, and it's not as if you will never use it...having a spare tire is a no brainer....with a diesel, the fuel system is just as important.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
crickeydog
Marietta, Ga.
Absolutely!!! I carry spare air, fuel, oil, & tranny filters...always.
Happy camping!!! See y'all down the road!!!
USAF RETIRED. "EITHER LEAD, FOLLOW, OR GET OUTTA THE WAY"!
PULL DOGS:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT "THE SILVER FOX" PRIMARY
2000 DODGE 3500 QUAD CAB DRW CTD LARAMIE "THE ROAD TRAIN LOCOMOTIVE" BACK-UP
2004 HOLIDAY RAMBLER PRES. 30 SCD 5'ER
lawnspecialties
Garner, NC
My opinion? No.
Change them regularly and relax.
2011 Ford F450 4X4
2011 Cyclone 370C
45Ricochet
North Idaho
Why not carry a spare just like your tire. My spare tire hasn't seen the ground and it sure weights a lot more.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
tempforce
Pacific Wonderland (in the summers)
when you have a filter start plugging you can always call a service to fix your rig. but if the filter isn't on their truck you will be faced with a tow.. so why not carry a spare filter, as you never know when the filter will stop bad fuel from getting to your engine. this is so much more important with a diesel vehicle as diesel in the u.s. is still a poorly filtered fuel...
somewhere in the texas 'lost pines'
'08' Dodge mega limo-cab, 409, kelderman rear air ride, max brake controller.
'02' 34' Holiday Rambler TT, the Gypsy Wagon.
'83' Ford Ranger with a 2.2 Diesel, little smoke
'56' F100 project truck
bob213
Fresno, CA
I always carry one. Make sure you know how to how to change it and how to prime the system if needed. Bad fuel puts you on the side of the road real quick. Been there...middle of Nowhere, Kansas. Glad I had a filter.
Camps with Critters
Been driving diesels for over 200,000 miles. Maybe I've been lucky? Have not had a fuel filter stop me yet, but I change more often than recommended. If you are experiencing a power loss tell your roadside assistance what truck/engine you have and that you may need a filter. All major parts stores carry replacements for the big 3. I just switched to a HDT a year ago and now carry a spare as it is not available at auto zone for my truck, but is the same filter as most OTR trucks so I will not likely ever need it if I keep changing it before it is "due".
Change often and buy fuel where the big boy trucks do, you will not likely ever need a spare.
05 Freightliner Century with Smart Car on the back
2010 Spacecraft 44.5 ft with a fully stocked bar-room
The Critters: Boogie & Jack (2 great dogs)
skipnchar
Topeka or somewhere else
I never carried a lot of extra parts since there is virtually no part of the USA that you can't buy common parts if they are needed. It is also pretty rare that a filter will need replacing between pre-scheduled changes. Just keep up on the preventative maintenance and you'll be very unlikely to ever need one unexpectedly.
Good luck / Skip
CKNEK
White Rock, B.C.
I hope I never need it but there is a spare fuel filter under the back seat in my truck.
With regular changes you might never need to use the spare, I keep one for a possible bad batch of fuel or winter gelling. The truck is now 5 years old and touch wood I have never had to use the spare.
07 GMC CCSB Duramax with a few goodies.
