jimco205
Central Alabama
Have some previous water stains on the ceiling of the rv. Any suggestions for removing them?
donn0128
Pronounced Ore-gun
Try oxyclean carpet cleaner.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
John S.
Northern Virginia
allahs awesome cleaner at the dollar store. IT works....
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
Branson in Tucson
Tucson,AZ
Be careful not to soak the ceiling carpet or rub to hard. I had water spots also. I rubbed to hard and used water with a small amount of bleach. White carpet ceiling. After doing it, the carpet glue ran through and I had even a bigger problem. I landed up replacing the carpet in the bathroom ceiling. It leaked around the sky lite.
2oldman
Winchester WA
ceiling stain
Tinstar
McKinney, TX
You probably can't remove just a spot stain. You'll need to clean the whole panel where the stain is located. From there, you'll have to figure out if you need to clean other panels.
Never pass up a chance to go somewhere
RSchleder
iowa city, ia
It may help to know what your ceiling is made of, carpet?, vinyl?, other? When all else fails, call a dealer or your manufacturer and ask them what their cleaning crew uses, these folks have some amazing products!
Captain_Happy
Abilene, Texas
Here's what I do to mine every time a water stain shows up, and I still haven't figured out how or where it's coming from either. If you got a carpet cleaning machine with a hose hand attachment, just us it as you would on a floor carpet, except it's upside down. I spray on some cleaning solution and then use a small hand held brush to work the clean solution in, and then with the hand held hose i just vaccum it right off. The carpet needs to dry really well after your done cleaning.
phillyg
Front Royal, VA
Captain_Happy wrote: Here's what I do to mine every time a water stain shows up, and I still haven't figured out how or where it's coming from either. If you got a carpet cleaning machine with a hose hand attachment, just us it as you would on a floor carpet, except it's upside down. I spray on some cleaning solution and then use a small hand held brush to work the clean solution in, and then with the hand held hose i just vaccum it right off. The carpet needs to dry really well after your done cleaning.
x2, but spray a hot Oxyclean solution on first with a small spray bottle.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
cvbdsl
Winchester, ON
phillyg wrote: Captain_Happy wrote: Here's what I do to mine every time a water stain shows up, and I still haven't figured out how or where it's coming from either. If you got a carpet cleaning machine with a hose hand attachment, just us it as you would on a floor carpet, except it's upside down. I spray on some cleaning solution and then use a small hand held brush to work the clean solution in, and then with the hand held hose i just vaccum it right off. The carpet needs to dry really well after your done cleaning.
X3 with the Oxcyclean and carpet cleaner hand vacuum attachment. By sucking out most of the water after a few minutes you reduce the risk of the glue letting go and it dries an lot quicker. Certainly worked for me.
Chris
2003 Dutch Star 4005
1999 Dutch Star DP 3865
2001 Honda CRV - Ready Brute Elite Tow Bar/Blue Ox Base plate
Retired Canadian Army WO (1971-2000)
