RV.Net Open Roads Forum: Tech Issues: Solar Power 101
 > Solar Power 101
Mello Mike
Mesa, AZ
Posted: 02/04/12 09:48am Link  |  Print  |  Notify Moderator
I recently completed writing a short piece on the basics of RV solar power. Feedback on the content would be greatly appreciated.
Solar Power 101
* This post was edited 02/04/12 10:33am by Mello Mike *
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
KJINTF
Montana
Posted: 02/04/12 10:40am Link  |  Print  |  Notify Moderator
Mike
Looks like a good start
What is it you are trying to accomplish with the primer?
There are several technical inconsistencies and miss leading statements
Happy to send my comments to you directly
Check your explanation of how solar panels generate voltage / power....
PWM controllers do not vary their operating frequency only their duty cycle
MPPT controllers charge the battery via a PWM operation after the front end array scan and buck conversion.
Ken
Always more projects than time
CA Traveler
The Western States
Posted: 02/04/12 11:14am Link  |  Print  |  Notify Moderator
Nice article, my suggestions:
Clarify 30% efficiency as that's misleading. Change to 10% and higher is possible under limited special circumstances.
Clarify that a 12V panel is for a 12V battery and the actual panel voltage is about 17V. Ditto 24V. Newbies get confusted by this.
"If your system is small, and is used perhaps six to eight times a year, then a PMW will more than suffice." This is misleading for a properly setup PWM system can be quite good for extended use. Also if I recall you said PWM controllers for up to 60A were available - handly small for a RV.
I'd like to see the battery section improved. Many RVers think that a marine deep cycle starting battery is a deep cycle battery. Explain that a marine deep cycle battery is slightly better than a starting battery but not nearly as good as a true deep cycle battery for RV house usage. And while there are 12V deep cycle batteries they are costly and not easy to find.
Personally I don't give the 2 12V vs 2 6V redundancy suggesion much credit. If a 12V battery shorts, kiss both batteries goodby. If a 12V battery opens the other battery won't last long but you will have some redundancy. Your example is interesting but a mechanically destroyed battery - OK I get it you still have the other battery available.
Please take the above as trying to be helpful for your nice article.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
renoman69
Edmonton Alberta
Posted: 02/04/12 12:11pm Link  |  Print  |  Notify Moderator
Good job Mike. I liked the write up. I took the liberty of adding your installation website HERE.
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
Mello Mike
Mesa, AZ
Posted: 02/04/12 05:15pm Link  |  Print  |  Notify Moderator
Thanks, gentlemen. I appreciate the feedback. Good stuff.
KJINTF,
The purpose of the article is to provide a basic understanding of how a solar system works in an RV. Nothing too detailed, just enough to make one dangerous.
Mike
BFL13
Victoria, BC
Posted: 02/04/12 05:35pm Link  |  Print  |  Notify Moderator
Good write-up.
I think the diagram at the start should show a representative battery fuse/CB at the pos post.
The two 6s vs 12 should specify two 12s to make it a fair fight.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
kab449
PA
Posted: 02/04/12 07:13pm Link  |  Print  |  Notify Moderator
Mike:
From an absolute newbie with no solar experience at all I thought the article was well written, easily understood, and gave me enough of information to make me want to explore this subject further.
Good job.
2011 F250 Lariat,SRW,Crew,6.7TD,ShortBox
2012 Montana 3750FL
Reese 18K Elite/Hidden Rails
Mello Mike
Mesa, AZ
Posted: 02/04/12 08:36pm Link  |  Print  |  Notify Moderator
BFL13 wrote:
Good write-up.
Great point about the fuses/CBs. I've always used them in my solar and inverter installations but left them out of this writeup.
Mello Mike
Mesa, AZ
Posted: 02/04/12 08:37pm Link  |  Print  |  Notify Moderator
kab449 wrote:
Mike:
Good job.
Thanks, Kab. That's exactly what I was hoping for when I wrote it.
CJW8
Arizona
Posted: 02/06/12 12:21am Link  |  Print  |  Notify Moderator
Good that you did say use a wire size chart but then you go on to say that "most professional installers use 10-2 and 8-2", implying that that is OK. In my opinion, that is too small of a wire size for most installations unless your using a higher voltage panel or series wired array.
2013 F350 PSD FX4 SB CC, 18,000 Superglide
2003 37SP Forest River Sierra Toyhauler (40')
2008 Polaris RZR
405 Watts of Kyocera solar panels, Rogue 3024 Charge Controller
 > Solar Power 101
