RV.Net Open Roads Forum: Class A Motorhomes: Motor Shield Question
 > Motor Shield Question
Stingme62
Kansas
Posted: 02/05/12 05:32am Link  |  Print  |  Notify Moderator
Hello,
I drive a 97 Holiday Rambler Vacationer with the Ford 454 engine and have done all the work myself so far on it, with the some help of many of you here on this forum. It is running perfect! However I do have one question about a possible motor shield. If you look under the passenger front wheel in order to get to the motor like to change spark plugs you have to remove about 6 screws that hold a cover. When you do the same on the drivers side it does not have this cover. I was wondering if there is anyone here who is really familar with this model that could tell me if this is correct or it is indeed missing that cover/shield.
Thank you!
Sting
SRT
Head of the Lakes, MN
Posted: 02/05/12 06:06am Link  |  Print  |  Notify Moderator
My MY2000 Vacationer doesn't have that shield setup with the V10, IIRC. BTW, a 454 is a Chevy engine. A 460 is the earlier Ford engine.
SRT
2000 32' HR Vacationer with Banks
1998 Subaru Outback Ltd. 5 spd
Brake Buddy & Blue Ox Aventa II tow bar
FMCA #266040 HRRVC #84109
Stingme62
Kansas
Posted: 02/05/12 06:23am Link  |  Print  |  Notify Moderator
Hey, thanks. That's good to know. Sorry about the 454, I meant 460 lol. I've done that a couple of times on this forum. lol
Lt46
Central Florida
Posted: 02/05/12 08:10am Link  |  Print  |  Notify Moderator
I believe you are talking about the heat shield for the plug wires. Yes, there are shields on both manifolds. My conversion to using headers wouldn't allow the reuse of the heat shields so my plug wires have heat shield boots over each wire. I've been operating this way for 2 years and haven't had a plug wire problem yet. I believe a new set of hi-temp. plug wires, backed up with boot shields will allow for elimination of the OEM shields.
Peter & Dawn
97 Winnebago Adventurer 37RW
96 Prowler 27X SOLD
IAFF L-792
Stingme62
Kansas
Posted: 02/06/12 01:31pm Link  |  Print  |  Notify Moderator
Hi Lt46,
I have the heat shields for the plug wires. This shield/cover is a small metal piece that blocks off the engine compartment. I have to remove this piece on my passenger side, my driver side does not have this cover. I just wanted to make sure this is standard with my make and model. Having replaced the exhaust manifold on that side you would think there would be a cover there. This would protect the motor and exhaust manifold from water being drawn up around the wheel. If the exhuast manifold is hot, you would think that could cause it to crack.
crasster
Dallas
Posted: 02/06/12 02:13pm Link  |  Print  |  Notify Moderator
I know exactly what you are talking about, but I have NEVER seen those with motor guards.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
