TTguy
NH
I live in Florida and I thought maybe the thermal pane windows would be a good option in a new fifth wheel to help keep the unit cool in during the hot florida summers. I am looking at a Cedar Creek 36B4 fifth wheel. Any feedback would be great.
Enjoy the Ride!
2005 GMC Sierra 2500 Diesel
2005 Jayco Eagle 298BHS
Prodigy Brake Controller
NC Hauler
Asheville NC
..LOT"S of threads have been posted on the pro's and con's of dual pane windows. I have them and swear by them....mine are almost 6 yrs. old and zero issues with them...I think they help with cooling a 5er quicker in the hot months and believe it helps with heating them up quicker in the cold months...my experience and like a lot of others, I wouldn't own a 5er without them...You'll get a few mixed reviews, but the majority like theirs and would have them again...
You can do a search for either "thermal pane windows" or "dual pane windows"....odds are, you have a "dual pane window" and though there are those who will swear they are of no help at all when it comes to heating or cooling a unit, most, like me, believe differently...they also keep it quieter inside your 5er from outside noises....I vote "yes" for them...hope this helped.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
jwb187
Southeast Missouri
I have them on mine and really believe they help on insulation and also on noise reduction. I had the opportunity to get them when I ordered new, they are pricey if you replace your original windows with them.
2008 Chevrolet Crewcab LTZ 4X4 duramax/allison
2008 Big Horn 3055RL 5'ver
Kipor 3500ti Genny
2005 Yamaha Rhino 660
60 gal aux tank/tool box combo
korbe
Northern California
If I was planning on LIVING in my unit during hot or cold weather, it would be a plus.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
hone eagle
essex ontario canada
My trailer is a 2002 and no issues ,I love them and would spec them again.
2005 Volvo 670 singled freedomline 12 speed
2002 Triple E 30' 5th
Hensley trailersaver TSLB2H
JEBar
Willow Springs, NC
from what I've been told regular camper window glass carry an insulation rating of R-1 .... thermopane/dual pane windows carry a rating of R-2 .... while that is significant it is only one insulation factor which it might pay for folks to consider, that is often overlooked, is the amount of insulation in the slide floor(s) of the camper they are considering .... it often comes as a surprise to folks that there simply isn't any insulation in most RV slide floors .... most have some sort of outer covering to keep out water (for some that is paint), section of ply board, and the carpet ... we have thermopane windows in our camper and like them, we have uninsulated slide floors and really wish we did
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
n7bsn
Yes
I have them and love them for three reasons: they don't fog-up or sweat as much, they keep the cold out, they keep the heat out.
I suspect most that hate them, are not owners of the more current versions. Some of the older versions where, well, not quite so good.
Jim also makes some good points about insulation, the rig has to be well insulated and well sealed (ie no air leaks)
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
dqdick
Council Grove, KS
We have them and camped in Kansas last summer when it was 113 degrees and camped this winter when it was well below freezing. Wouldn't have a rig without them.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
MTPockets1
Can't tell you what specific window thermal rating is, but I do know they make a considerable difference ...... Well worth the money - hot or cold or in between... If you only use the unit 3 -4 weeks per year, maybe not - I would, but may not be as important to everyone.
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
DaSu
St. Cloud Mn.
n7bsn wrote: I have them and love them for three reasons: they don't fog-up or sweat as much, they keep the cold out, they keep the heat out.
Jim also makes some good points about insulation, the rig has to be well insulated and well sealed (ie no air leaks) BINGO!!!!!!
2005 F250 6.0 Power Stroke SRW Crew Cab
2006 33'Jayco Eagle
"Life is Good"
