Problem with the Power gear leveling system on my 06 Jayco seneca
After starting and with ebrake on it goes throught its regular passe then all the lights stay on and it will nor run. will not do anything.
Google the model number with the fact all the lights stay on. There should be something helpful out there.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
I have the Power Gear leveling system, had a question about it, and could not find an answer on their web site. I emailed them and they emailed an answer the next morning.
2011 Fleetwood Southwind 32VS
2009 Ford Edge
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
Mode: Internal Error
Indication:
All of the light’s are on solid indefinitely
Cause:
This is an internal error
Fix:
A new control box is needed. However, a new touch pad is not needed
Grandma in front of her retirement home..
She lets Grumpy drive!!
I sent them a email still waiting to hear back, Checked the fluid and it was all good. Tried unpluging the controll panel to reset and pluged back in and nothing changed. Hope its not the control box as I hear they could be over $600. Anyone else have any ideas Also does anyone know where the fuses are located on the 06 35GS ?
Thanks
Also does anyone have a wiring schematic on this unit I'd like to go throught the wiring and see if its that. I'm scheptical to go out and get a control box. I had a problem with another unit I owned and they wanted to replace the control panel after searching found it was the connection at the control box was loose )already checked this on this unit.
edited 02/19/12 05:30pm by alpineman *
alpineman wrote: I sent them a email still waiting to hear back,
Don't hold your breath waiting. I was serious in my previous post. They will not talk to or correspond with their customers.
I have the service and repair manuals for mine that was in an 07 Seneca if you want them. They are in PDF format.
