RV.Net Open Roads Forum: Class C Motorhomes: o6 Seneca power gear leveling problems
 > o6 Seneca power gear leveling problems
alpineman
Alberta
Posted: 02/06/12 01:33pm Link  |  Print  |  Notify Moderator
Problem with the Power gear leveling system on my 06 Jayco seneca
After starting and with ebrake on it goes throught its regular passe then all the lights stay on and it will nor run. will not do anything.
ronfisherman
SE Michigan
Posted: 02/06/12 01:37pm Link  |  Print  |  Notify Moderator
If you do not get your answer here. Click on link in my signature. Kodiak owners on there with info on the various manufactures.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
Interlude
Northern California
Posted: 02/06/12 02:21pm Link  |  Print  |  Notify Moderator
I have an 06 Seneca, too. If you PM me with your email address, I'll send you a copy of the Powergear manual with trouble shooting tips.
Craig and Patricia
2006 Jayco Seneca 34SS .. Double Slide .. Duramax Diesel 6.6lly
Click Here for a Slideshow Tour.
alpineman
Alberta
Posted: 02/19/12 01:14pm Link  |  Print  |  Notify Moderator
I sent them a email still waiting to hear back, Checked the fluid and it was all good. Tried unpluging the controll panel to reset and pluged back in and nothing changed. Hope its not the control box as I hear they could be over $600. Anyone else have any ideas Also does anyone know where the fuses are located on the 06 35GS ?
Thanks
alpineman
Alberta
Posted: 02/19/12 05:15pm Link  |  Print  |  Notify Moderator
Also does anyone have a wiring schematic on this unit I'd like to go throught the wiring and see if its that. I'm scheptical to go out and get a control box. I had a problem with another unit I owned and they wanted to replace the control panel after searching found it was the connection at the control box was loose )already checked this on this unit.
* This post was edited 02/19/12 05:30pm by alpineman *
crasster
Dallas
Posted: 02/06/12 03:18pm Link  |  Print  |  Notify Moderator
Google the model number with the fact all the lights stay on. There should be something helpful out there.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Two Hands
California's Central Coast
Posted: 02/06/12 04:50pm Link  |  Print  |  Notify Moderator
I have the Power Gear leveling system, had a question about it, and could not find an answer on their web site. I emailed them and they emailed an answer the next morning.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
GrumpyandGrandma
Where ever Grandma tells me we're going.
Posted: 02/06/12 07:01pm Link  |  Print  |  Notify Moderator
Right from their web-site.
Mode: Internal Error
Indication:
All of the light’s are on solid indefinitely
Cause:
This is an internal error
Fix:
A new control box is needed. However, a new touch pad is not needed
Grandma in front of her retirement home..
She lets Grumpy drive!!
az99
NY.
Posted: 02/07/12 08:20am Link  |  Print  |  Notify Moderator
Don't bother calling them as they will not talk to their customers. It used to be a company with excellent CS.
az99
NY.
Posted: 02/19/12 06:46pm Link  |  Print  |  Notify Moderator
Don't hold your breath waiting. I was serious in my previous post. They will not talk to or correspond with their customers.
I have the service and repair manuals for mine that was in an 07 Seneca if you want them. They are in PDF format.
