retiredsnook
Canada
This works. Take your postal code ie. P3E 3R8 ..... take the numbers 338 and add two zeros 33800 put in as zip code. It
won't compromise the postal code on your credit card and it satisfies the US zip code request.
netjam
Canadian on the road
Currently in Texas and have found random 5 digits work most of the time. Have used your method as well but it doesn't always work. I think I had the most problem in the dakotas, Iowa etc. It might depend on which stations you use. Like I said, sometimes it works but sometimes it doesn't.
Don in Niagara
Niagara Falls, Ontario, Canada
It only worked one time and I tried it everytime we filled up in Texas.
The only time it worked was that one fill up in Rockport.
1990 Barth Regency 34'
Spartan/Cummins 8.3
Ka Ron
Kelowna
We have solved the problem by my wife taking the card in and waiting inside while we fill up.
Never had to use a code at the pump that way.
Join Us For A Trip Down The RV Highway
Falcon35
Waterloo ON Canada
I have not been able to make the 000 thing work in TX this year.
A few years back it almost always worked.
edited 02/07/12 10:57am by Falcon35 *
2012 Georgetown 378TS 2008 Honda Fit
ReadyBrake Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Fizz
Ottawa, Canada
A couple of Winters back I realized I needed that walk back and forth to the service station every 4 hrs. I got to know almost exactly how much gas I needed and payed in cash, in-out quick.
Lorne&Lorraine
Ottawa, ON
retiredsnook wrote: This works. Take your postal code ie. P3E 3R8 ..... take the numbers 338 and add two zeros 33800 put in as zip code. It
This only works sometimes and then only when the address verification system (AVS) has not been fully implemented at the station in question. AVS compares the zip code you enter at the pump with the zip code on file with your credit card issuer. There is no zip code or postal code on the credit card itself. There are a number of solutions. I put a US address on my credit card for the time I am in the states and this works all the time everywhere. Some, but not all, CDN debit cards with PIN will work at some stations (both the bank issuing the card and the station must be associated with the NYCE network). CDN banks generally levy a fee for using a debit card in the US. No fee for using a US bank issued debit card with PIN and it will work at all stations.
Lorne Ross
2003 Pleasure-Way Ford Excel TD
Camped the lower 48 states and 9 provinces
Most multiple times and now on the repeat!
onehorsehitcher
Donna Tx
I am not sure if is the dealer or the credit card companies requiring zip codes. I always notify my card company when we leave home to come down here. Recently at HEB pump I was required by the message to punch the zip and it refused. I used the home one and it worked. It does alert the card company that you are in a different zip. More pumps are requiring it. A bit of a hassle but if it is for my protection, good.
jetboater454
Camping or home
OK,now you got me wondering.Any problems going from the US to Canada and using a c/c at the pumps? Do they even ask for a zip code up there?
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
moisheh
North America
We were recently in Q and I stopped to fill up the toad. A fellow Canadian was having trouble as he had a Canadian card. I punched in my US Zip and it woked fine. Lorne and Lorraine have given the bset answer. If the computer is looking for your actual zip code the adding 0's does NOT work. Otherwise you could enter any valid zip code.Try 90210!
Moisheh
