RV.Net Open Roads Forum: Fifth-Wheels: Might as well ban them all
 > Might as well ban them all
Page of 6
FastEagle
Taylors, SC
Posted: 02/07/12 01:34pm Link  |  Print  |  Notify Moderator
HTElectrical wrote:
Why was the ST vs LT tires
thread closed.
CapriRacer wrote:
I hesitate to bring this subject up - given that a previous thread went on so long and was eventually closed - but........
Perhaps I can help folks understand what may be going on between these 2 types of tires. It was clear in that closed thread that there are some mis-conceptions.
Ya' see, I am a tire engineer with a major tire manufacturer - over 30 years in the business. I've got quite a bit of insight into how this works.
Is anyone interested in reviving the discussion
All of the posts I read were pretty much spot on as far as being on topic, and if they strayed, it was the OP that was willing to answer, and he should of been able to decide what was on HIS topic and what wasn't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
QUOTE:
Disregarding the several usual members that don't like any kind of moderation, what is occurring in most of the tire threads is that there are a handful of members that take over the threads. Then the next step is they begin attacking each other and any that oppose them. At that point Frank and I start getting all kinds of notifies (most justified). It's a no win situation. We delete the out of line post and then have to either edit or delete all the posts quoting it. It takes a lot of time and is very discouraging.
We don't have any way of merging threads/posts as someone suggested so that is out.
We can let them run and ignore the notifies or try to control them to some degree which is the path I have chosen. If I had a separate sub-forum for them, I would probably opt to move them all there and let them run but there is no programming time available.
Admin
RV.net
END QUOTE:
FE
Dickinson, ND
kedanie
Albuquerque, NM
Posted: 02/07/12 02:05pm Link  |  Print  |  Notify Moderator
thread closed.
Unfortunately, you missed all the posts that had to be deleted. I saw most of them and believe that the moderator did the right thing. Certain individuals had jumped in with both feet and the arguments were starting. Frank tried to fix it, but it continued and they had no choice.
It's not the moderators that are the problem. It is the posters that get out of control that cause these things.
If the shoe fits, wear it!!!
Keith
Keith, Gloria & Charlie(Spoiled Rotten Boston Terrier)
2010 Damon Astoria 3470
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Viet Nam Veteran
CapriRacer
Somewhere in the US
Posted: 02/07/12 03:35pm Link  |  Print  |  Notify Moderator
So, I'm making another attempt. I decided that this topic might be better if it wasn't just in the 5th wheel forum, so I put it in the Tech forum:
http://forums.goodsamclub.com/Index.cfm/fuseaction/thread/tid/25786030/p/1.cfm
Have fun, guys.
CapriRacer
Visit my web site: www.BarrysTireTech.com
SlickWillie
Coastal Bend Texas
Posted: 02/07/12 02:36pm Link  |  Print  |  Notify Moderator
Rats! I got on today specifically to read the tire thread by CapriRacer. That was the most informative tire threads I've ever seen. Oh well, stuff happens.
Will
2009 Chevy CC D/A 2500HD 4X4
2012 Rushmore 38CK
Duck
Miami Lakes, Fl
Posted: 02/07/12 03:15pm Link  |  Print  |  Notify Moderator
I would like to see the thread come back as a question answer thread. We could ask Capriracer a question and he could answer the question without anyone pilling on. We can decide on the quality of his answer.
Don
* This post was edited 02/07/12 03:30pm by an administrator/moderator *
08-FORD F350 PSD
13 Bighorn 3055RL
ExRocketScientist
Laurel, MD
Posted: 02/07/12 04:34pm Link  |  Print  |  Notify Moderator
ERS
NorthernLimits
Michigan
Posted: 02/07/12 06:37pm Link  |  Print  |  Notify Moderator
jdiffend wrote:
I have less of a problem with threads getting moved/closed/deleted than with the inconsistency of how it's approached.
I have been saying that for years.
NorthernLimits
Michigan
Posted: 02/07/12 06:44pm Link  |  Print  |  Notify Moderator
Admin
RV.net
The only thing I can say about all that is that maybe it's time to get different software then. vBulletin and about half a dozen other softwares have the ability to merge threads or posts and making a new sub-forum takes about 10 minutes.
Just saying that this software is pretty limited and maybe not the best business solution.
RVUSA
Orlando, FL, USA
Posted: 02/07/12 06:49pm Link  |  Print  |  Notify Moderator
no need for a software change,
If it's always the same few people, then the answer is simple. Pull them aside and warn them, and then remove them if need be.
Simple.
45Ricochet
North Idaho
Have fun, guys.
Just trying to help
Opps I see someone else posted the link
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Page of 6
