KampingKris
Folsom, CA USA
Everything running great... then all AC flipped off. Now, nothing AC... no charging of batteries either.. And it's going to be plenty cold here tonight... Must be a fuse but WHERE???
Granted, we had a couple electric heaters so must have overloaded the system but the breakers are fine and the pedestal is fine...
IDEAS!!!
thanks
KampingKris & FiremanSteve
Jada - American Eskie princess
2003 GMC Sierra 3500
2006 Alpenlite Limited 34RLR
2010 Polaris 850XP
2008 Polaris RZR
rolnhome
Casa Grande, Az
The breakers can look on but be triped have you tried turning them off then back on.
We're in Arizona
USAFBILL
Alabama
Check to make sure you have power at the pole where you are plugged in, then the power plugs. As all power was lost this is the first place I would check.
KampingKris
Folsom, CA USA
Checked the power pole. It's fine. There's just no power to the trailer. The breakers are fine... I tripped them all. There's no battery charging but the control panel is lit.. which it shouldn't be unless it was sensing power. But it's not charging.
SO, either there is a fuse somewhere or the converter/inverter has died suddenly.
Any ideas where to look for a fuse?
rasteck
Northern California/East Bay
Extension cord to one of your heaters and work on it in the morning?
Get the multi meter out and start tracing.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
rolnhome
Casa Grande, Az
There are a couple " button" type breakers on the side of my inverter. Make sure one of those has not tripped "popped out" if so just push it firmly back in. Good Luck
Acampingwewillgo
I was going to say the Inverter too(if your RV has one)...I know that even though my MH is a 50amp unit, the inverter has only a 30 amp pass through and if you overload the outlets that are on the Inverter, you will trip those resettable breakers on it. Ive done it a couple of times myself when running a couple of electric heaters, an electric coffee pot plus the Micro-wave.
96 Vogue Prima Vista 37' CAT 3176B
Our Babies: Mollie, Rubie, Cassie and Maggie, all rescued Cavalier King Charles Spaniels
Rainbow Bridge: Laddie, Scoutie, Katie, Cooper, Kodie
Rally's and get togethers.....Lots
sirdrakejr
Las Vegas, Nevada
Check near where the power cord enters the trailer. See if there is a master breaker there. My Alfas had the master near the cord. Then go to the inside AC breakers and reset them all.
Frank
garym114
Bluff Dale, Texas
rasteck wrote: Extension cord to one of your heaters and work on it in the morning?
extension cord from the power pole
J-mans Dad
SF Bay Area
If you have a removable cordset (Marinco type fitting)make sure it's seated and tight. Usually it's a bayonet twist/turn to seat.
