RV.Net Open Roads Forum: Tech Issues: Generator races when load comes off
 > Generator races when load comes off
Sagecoachdriver
North Hills, CA
Posted: 02/06/12 08:49pm Link  |  Print  |  Notify Moderator
My Onan 4KW tends to race when I turn off the air conditioner, then comes down. Every once in a while it shuts down when I turn off the air. I checked the voltage and with out load it's 119-120. With the air on, it's 117-118 and when I shut off the air the volts jump to 122 and then after 5 seconds drops back to 119-120. Is this normal or is it out of adjustment. The Hz is around 59.7 to 59.9.
Nspect
York SC
Posted: 02/06/12 09:28pm Link  |  Print  |  Notify Moderator
Sounds like a sticking governor or carb needs cleaning or both.
Here is a good document:
http://www.flightsystems.com/pdf/onanrvtshootgd608.pdf
Bruce and Donna
2007 Forest River Wildwood 27RLSS
2003 GMC Sierra 1500 Z71 towing package
Putnam XDR hitch
Equalizer WD with 1k bars
Tekonsha Prodigy brake control
