geedo
north east us
My air conditioner only works on high fan and not on low fan. The compressor contineus to run with no fan. I have checked the wire to the best of my knowledge and wires seem to be in tack. Does any one have any ideas.
skylos
Columbus, OH
There is an open connection between the power input and the low speed fan power supply wire, but not between the power input and the compressor input wire.
I suspect a partially failed switch or a disconnected wire.
vietvet66-67
southeast penna.
Don't know about fans on ac units in rv's, but they may have a resister to change the speeds like in automotive units. If it goes bad, you will get one speed and not another. Just change it out with anew one if it does. Hope this helps.
2006 Chevy 3500 DRW LBZ/ALLY LT2 The "DREAM CATCHER"
1999 Newmar American Star Newmar Kountry Klub #19708
Curt Q20 P-2 Controller Vietnam Veteran 1966-1967
LIFE MEMBER OF THE VFW PROUD MEMBER 335 "DUALLY CLUB"
"GOD, GUTS, AND GUNS KEEP AMERICA FREE"
geedo
north east us
I was told to see if the heat pump would operate on low speed. I put the thermostat on electric and low fan. The fan goes high and the gas heat then goes on. Not making any headway so far.
Wills250psd
walnutcove NC
in the cieling unit there are several wires that plug in, I would remove the grill(4 screws) and look. they are in the front of the unit, I think one may have worked lose. if thats not it may be the thermostat or the circuit board in the upper unit that the wires plug in to.either way it should not be a major problem.
WeBeFulltimers
Here & There
It must be out of "low fan fluid"! I don't claim to be an a/c technician and know nothing about your problem, but how can anyone give advice on this subject when they don't know the manufacturer/brand/type of the a/c unit?
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO TIMBRENS PRODIGY REESE 16K KWIK-SLIDE***PACBRAKE PRXB 2012 MONTANA 3585SA
skylos
Columbus, OH
WeBeFulltimers wrote: It must be out of "low fan fluid"!  I don't claim to be an a/c technician and know nothing about your problem, but how can anyone give advice on this subject when they don't know the manufacturer/brand/type of the a/c unit?
Because those who know how to be A/C technicians know that they will always encounter models and makes they never worked on before, but that doesn't stop them from being able to fix them. They're fairly simple devices with a limited set of problems. Not knowing manufacturer/brand/type of the unit is not a significant obstruction to fixing it, none of them are complex. Kind of like how the make/model/manufacturer of a car doesn't stop anybody from troubleshooting a blown fuse.
