RV.Net Open Roads Forum: wiring in my inverter
fltioga89
oviedo, fl.
Posted: 02/07/12 11:41am Link  |  Print  |  Notify Moderator
Hi folks, ive gotten around to buying an inverter and im in the process of installing it and have mounted it under the dinnette seat which is also shared by the water pump . My main obstacle is tapping into the main cable from the house battery . It runs directly under the floor from under the hood (class c E350 ford) to the generator on the passenger rear side. I need to cut the positive cable and make a tap into it. There is no slack in the cable so im looking into getting a 2 lug junction block type thing and cutting and putting lug ends on and running the inverter pos. cable thru the floor and bolt it to one of the lugs . I dont see an easier way, does anyone have any suggestions or thoughts? thanks
2oldman
Winchester WA
Posted: 02/07/12 11:45am Link  |  Print  |  Notify Moderator
What about the negative? I guess you're ok with a small draw, but a larger one usually needs a direct connection.
John Wayne
Long Beach, Ca
Posted: 02/07/12 12:07pm Link  |  Print  |  Notify Moderator
How close is this to the Batt. I've always heard you want to keep the inverter as close to the batt's as posable and make the long run with the 120 volt wiring.
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
garym114
Bluff Dale, Texas
Posted: 02/07/12 12:54pm Link  |  Print  |  Notify Moderator
This is the best way, by far.
What is the capacity of the inverter and what is going to be connected??
donn0128
Pronounced Ore-gun
Posted: 02/07/12 01:22pm Link  |  Print  |  Notify Moderator
I think you need to rethink your install unless you are within two feet of the batteries. Move the inverter to a place as close to the battery as possible.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
fltioga89
oviedo, fl.
Posted: 02/07/12 04:22pm Link  |  Print  |  Notify Moderator
the inverter would be around 8 ft from the battery if i mount it under the dinnette, the battery along with the chassis battery are both mounted under the hood on either side of the radiator so theres not anyplace thats real close to mount the inverter.
as far as the negative cable i was going to just run that cable to the chassis . the inverter is a 1000 watt.
pianotuna
Regina, SK, Canada
Posted: 02/07/12 05:31pm Link  |  Print  |  Notify Moderator
Hi fltioga89,
8 feet and 120 amps when the inverter is running flat out. This is a bad idea. Here is why.
Solution:
1 conductor(s) per phase utilizing a 1/0 kcmil Copper conductor will limit the voltage drop to 1.98% or less when supplying 120 amps for 8 feet on a 12.6 volt system.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Winchester WA
Posted: 02/07/12 05:45pm Link  |  Print  |  Notify Moderator
Be very watchful of that connection when operating a heavy load. Lots of amps going thru there.
Happy Prospector
The Great Sonora Desert
Posted: 02/08/12 04:34am Link  |  Print  |  Notify Moderator
When I wired in my inverter I tapped into the battery wire with a copper split bolt connector, that way I did not have to cut into batt. cable and mess with installing lugs.
Good Luck, Kevin
Kevin
Retired, Fulltime RV'er
1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler
2007 Yamaha Grizzly 700 (Green-It's your Daddy)
One Tough Kitty Named Bob
wny_pat
Western NYS
Posted: 02/08/12 10:26am Link  |  Print  |  Notify Moderator
I know just enough about electric to be dangerous, so I will defer if I am wrong.
But why not mount the inverter much closer to the battery (not in the battery compartment cause you don't want spark there) and run romex to where ever you want your outlet to be?
