RV.Net Open Roads Forum: Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
 > Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
Page of 95
CapriRacer
Somewhere in the US
Posted: 02/27/12 09:29am Link  |  Print  |  Notify Moderator
JIMNLIN wrote:
..... My current trailer has a 11200 lb GVWR with 5200 lb axles. The trailer axle weights run from 9000 lbs to about 9400 lbs for longer trips (actual scaled weights). My LT215/85-16 E at 2680 lbs gives me 10720 lb of capacity and has plenty of reserve capacity.
Again, figuring another 15 percent of capacity above my trailer 11200 GVWR would put the trailers tire needs at around 13000 lbs.
IMO lets be careful about a one size fits all with a 15 percent above the trailers GVWR recommendation. It doesn't make cents or sense for many folks.
I note with great interest that if Jim had followed the detail, he would have realized that he is actually running his tires at 78.2% of the load for an ST tire - which is suspiciously close to the 85% value I started of with in the beginning.
CapriRacer
Visit my web site: www.BarrysTireTech.com
sh410
Northwest
Posted: 02/27/12 10:13am Link  |  Print  |  Notify Moderator
While I agree with your comments, judging from the many comments on this forum about useing the GVWR or CCC of a RV as the criteria for purchase with the intent of useing it all because of the sticker rating may reduce the margin of safety of the OEM tires.
Chris
Shelter Bay, Wa
Posted: 02/27/12 03:05pm Link  |  Print  |  Notify Moderator
FYI he would not be caught dead on a ST tire. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
FastEagle
Taylors, SC
Posted: 02/28/12 11:24am Link  |  Print  |  Notify Moderator
Chris wrote:
FastEagle wrote:
You can read this for another point of view.
FastEagle
Why didn't you just say "to re-read my options on ST tires" click here. What really is your agenda in regards to ST tires? You are not a qualified tire engineer and our personal record with them is not good. You were going to give up on them and now you are not!!!!
You are all over the internet promoting a product that many feel is a product with more faults than good points. Only good point appears to be that they are cheap to buy! And that is why then end up on trailers OEM.
Chris
Are you in the USA? We have free speach here. My point of view is just as acceptable in this forum as yours.
FE
FE
Bus driver Joe
Oceanside CA USA
Posted: 02/28/12 01:56pm Link  |  Print  |  Notify Moderator
2001 Komfort 30' Travel trailer w/ 2 slides weighing 10,200lb. Bee running Goodyear Marathons 225/75/R15 Load range D since new, but have had around 14 blowouts. Sick of wasting money on Goodyear, always purchased from Goodyear Tire Stores, many of which were Truck Centers. Another Dealer recommended Maxis Load range E. Research verified Load range D rated @ 2450 @ 65psi means I have been overloaded since new. Any history on performance of Maxis?
Appreciate, Bus Driver Joe
2001 Komfort 29TS, Ford F-250 Super Duty King cab 7.3 liter turbo diesel.
RandACampin
Kathleen, Georgia
Posted: 02/28/12 02:15pm Link  |  Print  |  Notify Moderator
FastEagle wrote:
Chris wrote:
FastEagle
Chris
FE
FE
Way to go FE! Once again the tire ruffians led by Chris in his attempt to stifle anyone who doesn’t worship the LT. He always accuses others of an agenda...his agenda is the worst. His agenda is to censure anyone with a differing point of view!
* This post was last edited 02/28/12 02:36pm by RandACampin *   View edit history
Francesca Knowles
Port Hadlock, Washington
Posted: 02/28/12 02:39pm Link  |  Print  |  Notify Moderator
This is a PERFECT ILLUSTRATION of where the fault for most trailer tire trouble lies:
Squarely at the feet of the people that built the TRAILER.
BusDriverJoe's tires were undersized to begin with. He's faithfully continued to replace them with exactly the same tires, just as the manufacturer recommends.
Except that the manufacturers recommendation is WRONG, and clearly decided on as the cheapest, very minimum required to get the vehicle off the production line at the lowest possible cost.
Outcome:
Joe's had 14 blowouts, and naturally he's sick of it so he's going to change the size...but also the brand!
Which is the best possible outcome as far as The American RV industry is concerned:[image]
[image] It's the fault of THE TIRE INDUSTRY! [image]
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
RandACampin
Kathleen, Georgia
Posted: 02/28/12 02:43pm Link  |  Print  |  Notify Moderator
Squarely at the feet of The Manufacturer.
Outcome:
Joe's had 14 blowouts, and naturally he's sick of it so he's going to change the size...but also the brand! [image]
First you correctly blame the Rv manufacterer and then blame the tire industry?
Chris
Shelter Bay, Wa
Posted: 02/28/12 04:18pm Link  |  Print  |  Notify Moderator
Is the 10200 the weight on the axles or the GVWR. Are you accounting for the pin weight? Chris
azjeffh
Full-timing the USA (formerly Chandler AZ)
Posted: 02/28/12 06:04pm Link  |  Print  |  Notify Moderator
2001 Komfort 30' Travel trailer w/ 2 slides weighing 10,200lb.... Research verified Load range D rated @ 2450 @ 65psi means I have been overloaded since new. Any history on performance of Maxis?
Joe,
Re: overloaded, remember the tires are not carrying the full 10,200 lbs. My trailer when fully loaded (propane and water included) weighed in at 10,170. However the weight on each tire (weighed individually) was between 1975 and 2025 lbs, the rest was pin weight. I had approx. 8000 lbs on my tires rated to carry 9800 lbs.
After experiencing tread separation on one tire (also a Marathon), I moved "up" to Maxxis 15" LRE's. They lasted 26 months before I experienced sidewall separation on 2 tires within miles of each other.
Most here have had good luck with Maxxis, I just had no luck with them or the other ST manufacturer I purchased from.
Good luck.
Jeff
Wonderful wife Robin
2016 F350 PSD Dually
2016 DRV 38RSSA
Page of 95
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
