RV.Net Open Roads Forum: Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
 > Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
Page of 95
FastEagle
Taylors, SC
Posted: 03/04/12 12:55pm Link  |  Print  |  Notify Moderator
[quote=Chris]
Sorry, double post.
FastEagle
* This post was edited 03/04/12 02:36pm by FastEagle *
Dickinson, ND
FastEagle
Taylors, SC
Posted: 03/04/12 01:03pm Link  |  Print  |  Notify Moderator
FastEagle wrote:
Chris wrote:
FE, you should get a job with Keystone and solve the issues with most of their larger trailers with GAWR of 6750 and two Marathon's rated to 3420. Have you contacted them about this terrible tire choice? If trailers came OEM with tires better suited to weight and use, then we would see a lot less tire threads. Chris
I’ve been to a couple of large RV shows lately and took lots of pictures. Here is one depicting just the figures you are talking about. Keystone has learned nothing about their OE tires in more than 10 years. And their OE supplier here is GY with tires rated at 3420# that just barely meet the vehicle’s GAWR. BUYERS BEWARE!!!
Keystone Placarding
FastEagle
Francesca Knowles
Port Hadlock, Washington
Posted: 03/04/12 02:19pm Link  |  Print  |  Notify Moderator
Hoo boy!
Here's a beaut of a chance to watch the DIY version of the RV Industry's "attention to suspension" process from the ground up!
The fellow that just started this thread here at RV.net might benefit from a few words of wisdom from those of you that understand such things as matching frame etc. to load.
DeadeyeLefty wrote:
I started with a tent trailer - $50 on craigslist. Once the body was off, the build could begin:
This is the completed but not yet glassed deck:
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Chris
Shelter Bay, Wa
Posted: 03/04/12 05:24pm Link  |  Print  |  Notify Moderator
FastEagle wrote:
Keystone Placarding
FastEagle
I believe Tireco or Tredit are in the middle between Goodyear and Keystone with both Goodyear and Keystone turning a bind eye to the issues. Carriage was not much better with rebranded Duro tires at 3520 on 7K axles.
60 Minutes should do a feature on it. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
sh410
Northwest
Posted: 03/04/12 05:37pm Link  |  Print  |  Notify Moderator
FastEagle wrote:
Keystone Placarding
FastEagle
FE
If this placard is off of a Keystone 5th wheel, And the GVWR of 15,500# then 20% (est) of the GVWR is on the hitch pin. That would leave 12400 of GVWR on the Tires. The tires total 13680, represent 10% margin over the expected GVWR that is carried by the tires.
Have I computed this correctly?
Chris
Shelter Bay, Wa
Posted: 03/04/12 05:58pm Link  |  Print  |  Notify Moderator
sh410 wrote:
FastEagle wrote:
Keystone Placarding
FastEagle
FE
Combined GAWR is 13500 and tires add up to 13680. Not much leway there. Chris
JIMNLIN
out here
Posted: 03/04/12 06:28pm Link  |  Print  |  Notify Moderator
Francesca Knowles wrote:
Sorry if this is redundant...Can/will you post a link to the regs you snip from above?
http://www.access.gpo.gov/nara/cfr/waisidx_10/49cfr571_10.html
These are the 49 CFR 571 FMVSS regs that all vehicle manufacurers are required to follow. Click on 571.110 for tire and rim selection for vehicles under 10000 lbs and go to para S4.2.2.2 .
For vehicles over 10000 lbs click on 571.120 and go to para S5.1.2 which says the same thing.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Francesca Knowles
Posted: 03/04/12 06:31pm Link  |  Print  |  Notify Moderator
Bookmark added....
Thanks a lot- That's a great resource for the ol' toolbox!
FastEagle
Taylors, SC
Posted: 03/04/12 07:30pm Link  |  Print  |  Notify Moderator
sh410 wrote:
FastEagle wrote:
Keystone Placarding
FastEagle
FE
GTW is what a trailer is supposed to weigh when delivered to the new owner. The CCC placard will list the maximum amount of cargo that can be added to the GTW. When added together those two cannot be more than the vehicle’s GVWR. At that point the only way to find the pin weight is to weigh it. Once the pin weight is deducted from the GTW the remainder - GAW - is what’s being carried by the axles. That weight cannot be more than the GAWR. OE tires must have a total load capacity equal to or greater than GAWR.
Here is a reference with easy to use sheets to assist in weighing your trailer.
How to weigh your RV trailer
FastEagle
CapriRacer
Somewhere in the US
Posted: 03/05/12 06:41am Link  |  Print  |  Notify Moderator
In the interest of rapping this thread up, I have put my thoughts on my web site.
ST Tires
It includes a spreadsheet to aid in upsizing ST tires.
Look it over and let me know what you think.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Page of 95
