Ofc950
Northeast
I Have a problem with my hot water heater it auto lights then continues to click off and on for about 1 min. After about two min that flame goes out and it tries to re-light when it finally lights it has a loud pop from the build up of gas. Anyone have any ideas.
last
edited 02/07/12 07:09pm by Ofc950 *
View edit history
Russ p
keystone Cougar
26SAB
2011 Ford F-150 SuperCrew 5.5 bed Eco-Boost
Reese16K-
Sidewinder
skipnchar
Topeka or somewhere else
Clean the burner and spark units plus the vent to the roof.
Good luck / Skip
badboy368
OHIO
it may be the air adjustment. mine did that and i adjusted it and it has been fine since. it was letting too much air in and was blowing the flame out. it is simple to do
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
Old-Biscuit
Across the USA
Any signs of sooting?
What does flame look like?
Does it always do this.....or just first time after not being used for awhile?
What year/make/model of 'water heater'?
Could be dirty burner/flue tube
Could be air adjustment
Could be dirty flame sensor
Could be misaligned burner tube
rockintom
Livingston, TX
Cracks me up.....we don't know what brand and model of WH and we're giving diagnois advice!
Rockintom
'12 Excel Limited GKE 33 ft., trailer named "Charm"
'05 1 ton Chevy DRW Max&Allie Racor 660 Aux. Fuel Filter
Line-x Reese 20K hitch Prodigy controller GM nurf bars and folding bed cover - truck named "Tug" Fulltiming
patinlouisiana
Baton Rouge, La
Ofc950 wrote: I ave a problem with my hot water heater .
Sorry I can't help myself....
I have a problem with hot water heaters also.
Who in their right mind wants to heat hot water? it is already hot!
Perhaps you have a problem with your water heater?
Might need to hook it up to a hose pipe
edited 02/07/12 07:29pm by patinlouisiana *
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
Ofc950
Northeast
Suburban model # sw6de 6 gal new in a 2012 cougar lite
Once it lights then ok until it tries to light again and then it overloads and pops again. There is some sooting after it pops.
spadoctor
Clinton Corners, NY
those water heaters need a ground wire installed between the ground terminal on the gas valve and the screw mounting the ignitor at the burner...poor ground screws up the system. Also...there are 2- 1/4" hex head screws located in the upper right hand corner looking from the outside. This is the point the ground connection is made from the module inside and the frame....loosen and retighten each screw....can have a poor ground here also. This has fixed many a problem on several campers for me
patinlouisiana
Baton Rouge, La
ScottG wrote: Along with Master Biscuits advice, I suggest getting some carburetor spray cleaner and washing down the flame sensor and burner area. This stuff will melt carbon and often will solve these kinds of issues and if it doesn't, at least it's all good and clean.
I think this stuff is flamable so make sure power and gas are shut off before using.
Just saying...
ScottG
Bothell Wa.
Scott, Grace and Wesly
H0NDA eu2000i
