RV.Net Open Roads Forum: The one specific suggestion you would make to RV makers...
 > The one specific suggestion you would make to RV makers...
Page of 11
barbandwayne
Eastern Arkansas
Posted: 02/24/12 08:59am Link  |  Print  |  Notify Moderator
I haven't read all 6 pages of this thread but my biggest concern is why in the world do they put carpeting right at the door? Give me a little spot of tile or vinyl at the door to catch the dirt that you can't help but bring in on your feet.
Atlee
Mechanicsville, VA
Posted: 02/24/12 09:49am Link  |  Print  |  Notify Moderator
I know Skyline makers of Aljo, Nomad, Koala & other trailers does exactly that. Each trailer has weight plate stamped and attached. It's the weight of the trailer and includes all the options that were factory added.
recycler wrote:
skipole wrote:
Atlee wrote:
Kennedycamper wrote:
I would like to see sales brocures with real weights, and the weight that all options add. Then people wouldn't have to guess if thier truck would haul it. Also more areo dynamic trailers for better MPG.
I'm not sure they can put the real weight since each trailer may have different options added at the factory. That said, they should add the pounds of each option they mention in their brochure. Also, what a filled 20# LPG bottle weights, and what the weight of the battery they put in the TT.
If they would just put those numbers in the brochure, it would help a great deal.
I'd be happy if they put the real as built weight on the sticker. Manufactures should buy a set of scales and as the final step in the build get the actual four corner weights.
Just my opinion.
Ski
i agree how hard is it too set a rv on a scale and weight it as it goes out the door those of the tc crowd would greatly apperciate this step
Erroll, Mary, Duffy the Badger Dog plus "Ollie"
2009 HiLo Towlite 2209T
2005 F150 Supercab 4x4, w/ 5.4L
1996 RoadTrek 210 Popular, on 1995 Chevy Chassis
motorhomi
whitmore lake m i usa
Posted: 02/24/12 02:45pm Link  |  Print  |  Notify Moderator
Please NO MIRRORS, I know my MH is small, putting mirrors up inside is not fooling me that it is bigger. They are ugly.
Retired Phone Man
Covington, Louisiana
Posted: 02/24/12 10:58am Link  |  Print  |  Notify Moderator
Handle your warranty claims instead of referring the customer to an outside vendor. A few years ago I had problem with axles on my TT and Gulf Stream said that was covered by Dexter Axle and they could do nothing for me. Won't be buying from Gulf Stream again.
Jim
2007 Toyota Tundra SR5 Double Cab with 5.7L V8 and Tow Package.
2007 Gulf Stream Ameri-Lite 21MB
Peaches - Lhasa Apso/Mut Mix
tomman58
Southeast Michigan
Posted: 02/24/12 01:17pm Link  |  Print  |  Notify Moderator
When we buy our trailers we get as little carpet as possible (Jayco gives option). I would rather wash a throw rug than put up with a stained carpet or worn one. Vinyl wares much better in the woods and sand where we go.
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
rvten
Crossville,TN
Posted: 02/24/12 01:28pm Link  |  Print  |  Notify Moderator
Sewer Hose storage already built in to the RV. To handle 10/20 ft hose. Also not in same compartment with fresh water connection.
A surgeguard system ( or alike mfg. device) installed as standard equipment.
More outlets both 12V and 120V. Seams they always put them where not needed.
Option to have carpet or no carpet in all of RV.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
ExRocketScientist
Laurel, MD
Posted: 02/24/12 04:20pm Link  |  Print  |  Notify Moderator
On the trailers it would be nice if they could increase the size of the "sewer hose" bumpers to 5" with a plastic liner. Then we could really use them.
ERS
K3WE
Missouri
Posted: 02/24/12 04:50pm Link  |  Print  |  Notify Moderator
They are much to big on the outside and too small on the inside. Stupid that they cannot do something about that.
EPenney
Galt, Ca
Posted: 02/24/12 06:02pm Link  |  Print  |  Notify Moderator
Don't know what percentage of folks drycamp -vs- stay at FU CGs, but having the TT/5er set up for 4 batteries would be nice.
We drycamp mostly, and our 5er has a battery bay big enough to fit four 6-volt batteries, but the way the racks are set up, along with the size and location of the access door make it impossible to fit more than 2 batteries.
'07 Chevy 2500HD Silverado "Classic" CC D/A 4x4
'07 Komfort Trailblazer T252FS fifth wheel
Reese Signature 18K Slider and other stuff.....some useful.....some not
magnusfide
On the Road Again and Again and Again...
Posted: 04/28/12 10:44pm Link  |  Print  |  Notify Moderator
mlts22 wrote:
If I had to make one specific suggestion to RV makers for quality improvement, I would probably ask the ones who use rubber/EPDM roofs to use properly applied EternaBond on all roof joints and seams from the factory, and use caulking as a secondary measure to keep the EB edges from getting dirty as opposed to being the primary/only means of keeping water out.
I wonder what other people's suggestions would be.
Ditto. If RV manufacturers could only afford to make one change, this would be it. Water tight roof and seams that have Eternabond or its equivalent in durability and strength.
A ceiling to floor closet to accommodate those long items of clothing such as full coats and longer dresses would be icing on the proverbial cake. Doesn't have to be very wide at all.
First law of science: don't spit into the wind.
Keep on rollin'!
Magnus
Page of 11
