RV.Net Open Roads Forum: Class A Motorhomes: Toilet Paper
 > Toilet Paper
John&Joey
Some Location
Posted: 02/08/12 03:15pm Link  |  Print  |  Notify Moderator
Jamboree89 wrote:
Angel Soft toilet paper at Walmart.
X2 100%
Soft, strong, septic safe, and can be found just about everywhere. What you don't want is paper that will jam into the slide valve when you close it. Most slides are easy to replace, a few are a real PITA.
Maddawgs
central MA
Posted: 02/08/12 03:29pm Link  |  Print  |  Notify Moderator
Williamh wrote:
Sometime back, I was at grocery store or Sams club type store and saw some toilet paper marked "safe for septic and rv use". Recently I have been looking at different stores and cannot find toilet paper marked for rv use other than that found at Walmart in their camping section or at a camping dealer. My question is does anyone know what brand of toilet paper can be used in RV's or marked for RV use. I am concerned about the paper disintergrating and or cloging the tank on my Motorhome. Thanks for any help in finding this.
William
If you are unsure of a certain brand, take a few sheets of whatever brand you want to check and put them in a large gallon sized pitcher. Let them sit overnight. Some time during the next day take a look. A good septic safe brand will have broken up into kind of a mush. I found one of those environmentally safe 100% recycled brands that did this. I forget what it was called mother earth or earth safe or something along those lines. One roll cost as much as a 4 pack of Scotts basic 2 ply. If when you check the sheets are still together, give the pitcher a shake or stir up the water a little (this simulates adding refuse to your tank). If the sheets brake up then it is septic safe (Scotts basic 2 ply will and this is what I use), if the sheets don't break up then don't use them. Hope this helps you out.
Todd
Todd, Shirley, and the "Maddawgs" min-pins Precious and Buster Brown
2011 Itasca Cambria 30C
2011 Demco KarKaddy 460SS
TST 507 RV TPMS
"if there is anything left when we are gone, then we miscalculated"
Tinstar
McKinney, TX
Posted: 02/08/12 03:55pm Link  |  Print  |  Notify Moderator
Angel Soft
Never pass up a chance to go somewhere
sdianel
Tampa, FL
Posted: 02/08/12 03:58pm Link  |  Print  |  Notify Moderator
We use Scotts which states "safe for RV and septic"
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
RV daytrader
PA
Posted: 02/08/12 04:10pm Link  |  Print  |  Notify Moderator
Most TP is safe if used sparingly.
* This post was edited 02/09/12 09:24am by an administrator/moderator *
YODA...our lil Toyota!
1989 Toyota Seabreeze
univmd
Maryland
Posted: 02/08/12 04:23pm Link  |  Print  |  Notify Moderator
Our Scotts does not state, "safe for RV and septic."
2008 Gulfstream Tourmaster
2011 Honda CRV
Blue Ox Baseplate & Socket Wiring
Blue Ox Alladin Tow Bar
US Gear Unified Tow Brake
s N s
Michigan
Posted: 02/08/12 05:18pm Link  |  Print  |  Notify Moderator
We use Scotts 1000 1 ply. Have never been a problem for us.
Steve & Sally
HiTee & Hudson (Our Little Poms)
Houston & Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 pt Cruiser Vert 5 speed
Demco baseplate with Commander Tow Bar
"Never try to outsmart your common sense"
WillieD
Louisiana
Posted: 02/08/12 05:59pm Link  |  Print  |  Notify Moderator
We use any brand that is not the "John Wayne" type of TP. Never had an issue.
WillieD,MaryLee,and Sid
Fleetwood Excursion 40X & 2011 Colorado 4X4 Toad
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 02/08/12 07:23pm Link  |  Print  |  Notify Moderator
Costco brand for us.
down home
south
Posted: 02/08/12 09:27pm Link  |  Print  |  Notify Moderator
What kind did John Wayne use??
 > Toilet Paper
