RV.Net Open Roads Forum: Tech Issues: Charging Car Battery with Honda eu1000i
 > Charging Car Battery with Honda eu1000i
mitch5252
NW Tennessee
Posted: 02/08/12 03:04pm Link  |  Print  |  Notify Moderator
Battery is dead on my Sienna van. I would like to charge it with my new Honda eu1000i.
I have the "charging wires" that plug into the generator.
Do I start the generator first and then hook up to the battery, or hook up to the battery and then start the generator?
How long should I leave it running?
thanks for your help.
Regards,
Michelle
2008 Fun Finder X-160
2006 Toyota Sienna Limited
Equal-i-zer Hitch
Prodigy Brake Controller
mlts22
Austin, Texas
Posted: 02/08/12 03:13pm Link  |  Print  |  Notify Moderator
Start the generator first, so it can come up to speed and be able to take load, then hook up the wires.
I'd say that this is probably one of the worst ways to charge a battery, since the 12 volts won't help much, but it is better than nothing. After you get your van going, I recommend buying a "real" charger to have on hand, that can do decent amperage.
donn0128
Pronounced Ore-gun
Posted: 02/08/12 03:14pm Link  |  Print  |  Notify Moderator
The battery charge capability of that generator is about 1 amp. So that means you will have to let it run for about 18 hours to recharge the battery. I suggest you go out and buy a regular battery charger. Would be much faster and simpler.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
mitch5252
NW Tennessee
Posted: 02/08/12 03:15pm Link  |  Print  |  Notify Moderator
I have a real charger. I just wanted to run the generator. I'll go use the real charger.
Thanks.
Gale Hawkins
Murray, KY
Posted: 02/08/12 03:17pm Link  |  Print  |  Notify Moderator
I prefer to have any generator up and running before hitting it with a load.
If the 12 vdc output it only about 8 amps it could take many hours to get it fully charged but my guess you only want to be able to ge the car started and not to fully charge the battery?
If you have a conventional 12 volt battery charge will may charge faster depending on the charger.
Gale Hawkins
Murray, KY
Posted: 02/08/12 03:32pm Link  |  Print  |  Notify Moderator
Thanks.
Actually that is a good way to get some hours on the Honda and do something useful.
mitch5252
NW Tennessee
Posted: 02/08/12 03:38pm Link  |  Print  |  Notify Moderator
OP here...
I bought the generator to charge the trailer battery while dry camping in Canada and Alaska this summer. Hopefully, that wasn't a (an expensive) mistake?
Now here's a dumb question for you - I shouldn't run the "real" battery charger with the generator to charge the trailer battery, right?
Sigh.
old guy
Oregon (pronounced Or e gun)
Posted: 02/08/12 03:39pm Link  |  Print  |  Notify Moderator
owners manual states run genny for a minute or until it gets warmed up so it can handle a load then plug in appliance.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/08/12 03:42pm Link  |  Print  |  Notify Moderator
That generator will power a battery charger up to its (generator) design output rating.
rgraham
Missouri
Posted: 02/08/12 03:52pm Link  |  Print  |  Notify Moderator
Start the Generator up and plug the Battery charger into the 110 outlet on the generator, then hook the battery charger up to your battery red wire on plus post and black wire on the Negative post or Ground, have no ideal how long, I have a large size charger and it takes a hour, the smaller ones may take several hours,
Richard
1987 ford f250 6.9 diesel
1997 Innsbruck by Gulf Stream 28ft fifth wheel with slide
and the wife and co-pilot Trudy
