mena661
mitch5252 wrote:
Now here's a dumb question for you - I shouldn't run the "real" battery charger with the generator to charge the trailer battery, right?
Yes you should. How else are going to charge the battery?
Trojan L16 6V's 740 Amp-hours
mitch5252
NW Tennessee
By plugging the trailer electric cord directly into the generator? That's what I was thinking anyway...
2008 Fun Finder X-160
2006 Toyota Sienna Limited
Equal-i-zer Hitch
Prodigy Brake Controller
donn0128
Pronounced Ore-gun
Plug the generator into the trailer. You already have a great battery charger there.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
mitch5252
NW Tennessee
othertonka wrote: As I read the post, the OP wants to charge the CAR battery, not the trailer battery. Start the Genny and after it runs a minute or so, plug your battery charger directly into the genny and hook the charger up to the car charge away.
Would I have to run the generator for 18 hours as a previous poster said?
Using the eu1000i, would I be able to charge THE CAR BATTERY with the "real" battery charger on 12A for a while and them ramp it up to the 75A setting to start the car?
RoyB
King George, VA
Like stated above by a couple of users here go buy a B&D VEC1093DBD 40AMP Battery charger. This being a "SMART MODE" portable charger it will re-charge the truck battery back in as few as 2-3 hours of run time. It should re-charge it enough to get your truck started in 30 minutes or so.
You need to carry one of these with you anyway as part of your PLAN B to get always get you back home when you need to... i.e. if your converter in your trailer konks out on you the trailer batteries can get re-charged with one these B&D portable chargers as well by running it from the generator...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
othertonka
Stockton, CA
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
nitrohorse
pa
mitch5252 wrote: othertonka wrote: As I read the post, the OP wants to charge the CAR battery, not the trailer battery. Start the Genny and after it runs a minute or so, plug your battery charger directly into the genny and hook the charger up to the car charge away.
Mitch,
You have two options as I see it. You can start the genny, let it warm up, plug the real battery charger into the genny, and then hook up the charger cables to the battery (+ to +) and (- to -). Start the charger, switch it to the 75a mode (start boost) and start the car. The car's charging system will charge the battery much quicker than the 12a from the charger.
Or you can hook up the battery charger as listed above and charge the battery using the 12a function. The only issue I see with the 75a boost option is that your 1000 w gennie may not handle the 75a boost amp draw.
Maybe someone on here can answer the question if the 1000w Honda can power the 75a boost function.
Hope this helps....
jauguston
Bellingham, WA
A Honda EU 1000i will power a 40a RV converter. It will not power a 45a converter. I have one and know. If you are going to use the Honda 12v charge wires you will get about 8 amps. The Econo mode has to be off for the charge cables to work.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
dclark1946
Richardson,TX,USA
jauguston wrote: A Honda EU 1000i will power a 40a RV converter. It will not power a 45a converter. I have one and know. If you are going to use the Honda 12v charge wires you will get about 8 amps. The Econo mode has to be off for the charge cables to work.
Jim
Sure you can run a 45A converter with an EU1000i. I do it every year dry camping in the Smokies. You just don't run your battery down so low that the converter has to put out max current. I run our generator every morning for a few hours and peak current for a single Gr 27 Trojan SCS 200 battery rarely exceeds 10A on initial power up. You could have two 12V batteries and that would only be 20A max on initial power up. I let it run until the charging current drops to 3A or less.
I have a couple of EU2000s also but they stay at home when we are dry camping in favor of the easy on the back EU1000.
Dick
Dick & Karen
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/09 F250 V10
mitch5252
NW Tennessee
I think 75 amps on the "real" charger would ride the upper running limit of the generator...? ? (75A x 12V = 900W?)
But I know nothing for certain; certainly not a lot of math.
