RV.Net Open Roads Forum: Travel Trailers: wash and wax your trailer
 > wash and wax your trailer
old guy
Oregon (pronounced Or e gun)
Posted: 02/08/12 03:53pm Link  |  Print  |  Notify Moderator
Talked to Keystone rep yesterday and asked if washing and waxing your tt at the car wash with the pressure wand was OK. told me "NO". if you have the smallest leak,, you will have a major problem with leaks and eventually dry rot. hand waxing is not necessary, if you do insist on hand waxing, you should use an non abrasive wax. any brand is OK as long as it doesn't have any grit or abrasions in it. such as wax and cleaner waxes. a lite coat is all you need. I was hoping he would say it is OK to do the pressure washing and waxing, I have read so many time of people having sore shoulders for days after waxing their Tt or MH's. Just looking for the drinking mans method. Now I know you guys out there have an opinion, so let's hear them. OH yes, one more thing, he didn't say anything about what kind of brush or wool pad to use on a stick. He said a brush of your choice. that leaves that open for discussion.
MackinawMan
NW Ohio
Posted: 02/08/12 03:56pm Link  |  Print  |  Notify Moderator
Well I always used a garden hose before...then my family got me a small electric power washer for my birthday a few years ago and now I use that.
I'd have to say, that I could see what that salesman is saying....but for me, the little power-washer we have is much too weak IMHO to do any of the type of damage he's referring to.
It's basically just a bit stronger than a garden hose with the spray nozzle TBH. Not to mention I don't hold the end of the nozzle close to the TT anyway, it's always several feet away.
So, if you're asking about options I guess that's what I'm suggesting..a small electric power-washer.
2000 Ford F350 XLT 7.3L PSD CC 4x4 OffRoad SRW Long Bed
2008 Jayco Eagle 314BHDS (Momma Eagle)
Equalizer Hitch System (1400/14000lbs)
Prodigy Brake Controller
Curt XD Class V Receiver Hitch (1500/15000 lb)
Ka Ron
Kelowna
Here is my opinion.
We were traveling south for the winter one year and to roads were very bad. When we got down around Bakersfield I got this bright idea that a truck wash would work really well.
We drove in and three guys took after our rig with wands, brushes and I thought would make short work of the job.
When it came time for the rinse and they were using high pressure wands one of them found the stove vent. Look out we had water flying all over the kitchen on the inside.
Luckily that was the only spot water came in, but I have not done it since.
Join Us For A Trip Down The RV Highway
downtheroad
Pacific Northwest
Posted: 02/08/12 04:36pm Link  |  Print  |  Notify Moderator
Waxing with any clear coat safe auto wax is ok.
I haven't and would never use a pressure washer to wash our trailer.
Hose and brush only.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
catdaddyxx
Dumas, TX
Posted: 02/08/12 05:13pm Link  |  Print  |  Notify Moderator
I detail on the side, so I have a plethera of washes, waxes, etc...
I've been tempted to use my pressure washer on low but it's just about as fast by hand and brush so I've never messed with it.
I use a soft bristle brush on a stick, Meguiars Gold Class auto soap, and low pressure water to clean it. Also dry it with an aqua dry towel.
I wax once or twice a year with Colonite #845 insulator wax. It's not my favorite hand wax, but it's the best bang for the buck as far as something that lasts a long time and is easy on/off.
FWIW, most consumer line cleaner waxes have very little to no abrasives. They are loaded instead with fillers and would be perfectly safe to use.
2010 29' Jayco, Jay Flight 26BH First real camper
1960 Montgomery Ward popup with slide out galley.(Restored in 2010)
2004 Ford, F150 4x4 lariat 5.4L V8, 3.73 gears, pipes, FIPK, tuner.
Many many mods to the truck
tbrowne
Springfield, OH
The paint on aluminum skinned trailers is extremely thin, which is why the rep told you not to use anything with abrasives. You can easily rub through the paint with any cleaner that has even the finest abrasive in it. Automotive paint is much harder and more robust than RV paint. If a wax is labeled cleaner wax then avoid it.
Terry Browne
usmohls2@yahoo.com
CA
Posted: 02/08/12 05:21pm Link  |  Print  |  Notify Moderator
For years I washed my 5er with simple green & a window brush. Then hosed it down with a spray from the garden hose. Still looks new.
Charltons
Battle Ground, WA
Posted: 02/08/12 06:29pm Link  |  Print  |  Notify Moderator
Simple green works great, thats all I use. Per my "RV GUY" never use a pressure washer as they tend to tear/rip out the caulking and window seals as you spray over them.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
old guy
Posted: 02/08/12 07:05pm Link  |  Print  |  Notify Moderator
his main concern was the high pressure might take off some of the decals and get by the seals around the windows and slide outs. we did not really discuss the metal sided TT's I was mainly asking him about glass sided TT's.
Terryallan
Foothills NC
Posted: 02/08/12 07:31pm Link  |  Print  |  Notify Moderator
Been waxing my TT with cleaner wax for 8 years. Guess what. It looks like new. The wax takes off all the black streaks, and helps prevent them as well. I wouldn't use anything else. I might consult another sales rep though. That one knows little about waxing a TT.
As for the carwas. Mine won't fit under the roof.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
