RV.Net Open Roads Forum: Truck Campers: raising camper to clear truck roof
 > raising camper to clear truck roof
bobndot
NY
Posted: 02/09/12 07:15am Link  |  Print  |  Notify Moderator
Did you try looking here ?
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24581263.cfm
camper loading/jacks/hauling/tie downs shows guides
you could install something on the bottom of the camper too.
http://www.rv.net/forum/Index.cfm/fuseaction/thread/tid/16957495.cfm
mkirsch
Rochester, NY
Posted: 02/09/12 01:20pm Link  |  Print  |  Notify Moderator
The beauty of building a box out of 2x4s and plywood is you end up with a 3-1/2" high "basement" for storing stuff. Fishing poles, ladder, hoses, the tow strap, tools.... The possibilities are ENDLESS!
2x4 on edge is about 3-3/8" plus 23/32" (what they call 3/4") ply is about 4".
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
sundowners
suffolk UK
Posted: 02/09/12 02:20pm Link  |  Print  |  Notify Moderator
its a good idea to use the space created----------but if your camper drops over the back of your truck bed-----like ours-----how would you access it ? (without removing the camper)
Nigel & Pamala------Spain
arto_wa
SW, WA
Posted: 02/11/12 11:45am Link  |  Print  |  Notify Moderator
I have two layers of 2" HD pink foam, on top of a rubber mat!
* This post was edited 02/11/12 12:19pm by arto_wa *
99 F350 4x4 CC DRW 7.3L PSD, 97 Bigfoot 10.6
89 Duckworth 17' Pro 302
eagle777
N.CA
Posted: 06/01/12 11:57am Link  |  Print  |  Notify Moderator
scolew325 wrote:
I use a high density foam board under mine. It can be found at the big box stores fairly cheap. If you go that route just make sure its the high density, you will know right away if its not, it will smash down to nothing a few miles down the road.
is this the same board they sell as insulation...thks
jack
Manteca, ca
Horsetrader
Albany, Ohio
Posted: 06/01/12 01:24pm Link  |  Print  |  Notify Moderator
double post. rats
Horsetrader
Albany, Ohio
Posted: 06/01/12 01:25pm Link  |  Print  |  Notify Moderator
I used 2X4's with 1/2 plywood and topped it off with a 3/4 rubber stall mat from TSC. That made close to 3". Worked great for me.
eagle777
N.CA
Posted: 06/02/12 08:51am Link  |  Print  |  Notify Moderator
dont see my first post...so hi again, is this the same foam board they use as insallation...thks
Farmerjon
Niangua, missouri
Posted: 06/02/12 03:25pm Link  |  Print  |  Notify Moderator
We used 2x4s on their sides, not edges, and 3/4 plywood on that with a rubber mat on top. We have a spray on bed liner and the camper still moved around some.
so we added a strip of rubber ( baler belts )to the 2x4s that run the length of the bed and that ended that.
I just went out and measured it. It raises the camper 2 3/4 inches and clears the roof clearance lights by slightly more than 1 inch.
00 F350 SC LB 4x4 DRW 7.3 PSD 6sp 3.73 DYI over load bumpers
99 Starcraft 953
87 F250 460 4x4 4sp 4.11 ex cab 8ft
95 jeep YJ 4cyl 5sp
69 f250 360 4sp
Farmerjon
Niangua, missouri
Posted: 06/02/12 05:38pm Link  |  Print  |  Notify Moderator
also you might check the electric hook up , Lances can be wired different than most campers.
