RV.Net Open Roads Forum: Class A Motorhomes: Flooring change
 > Flooring change
barth
Shefford, QC
Posted: 02/11/12 11:43am Link  |  Print  |  Notify Moderator
I installed a floating laminate flooring.
The thickness is 12mm (about 1/2"). No problem with the slide.
missscarlet9
Saskatchewan
Posted: 02/11/12 05:13pm Link  |  Print  |  Notify Moderator
For those out there who have made the change from carpet to hard flooring, have you noticed a change in road noise while travelling? I'm in a DP and don't have engine noise. I'm considering tearing up the carpet in favor of lino or hardwood, but I am concerned of noise.
Livin' the dream!
wizzo442
Marion, Il
Posted: 02/11/12 07:54pm Link  |  Print  |  Notify Moderator
I replaced the carpet in my '06 Diplomat with laminate this past year. My slide goes up and over the laminate, so that's not an issue in my coach. Not all slides do that, however. I do not notice any difference in road noise with the laminate. I did put a thin (1/16") pad under the laminate but I doubt it has much noise cancelling property. The laminate is so much easier to clean and for those who think laminate is "cold", throw rugs are the answer. The only ones that don't like my laminate is my dogs. They "Scoobie Doo" on it when they get excited (another reason for throw rugs).
wizzo442
Marion, Il
Posted: 02/11/12 07:58pm Link  |  Print  |  Notify Moderator
Clay L
Sioux Falls, South Dakota
Posted: 02/12/12 08:25am Link  |  Print  |  Notify Moderator
I did not notice any noise increase but I have a gasser.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
PF&PM
Lethbridge, Alberta
Posted: 02/12/12 01:17pm Link  |  Print  |  Notify Moderator
Good post.. Do the slide slickers stay down or do you remove them when the slide is out.. and If you used Allure flooring do you even need them ..?
2005 Newmar 34' Kountry Star, 8.1L W22, Blue Ox 10K, Honda Pilot, Bijon Shitzu (Sassy) dash dog, Two teenage boys..we get around ! Nine Provinces, Two Territories, 47 States, Northern Mexico... so far..
koda55
Jacksonville
Posted: 02/12/12 01:43pm Link  |  Print  |  Notify Moderator
I put the allure flooring down and the slides do not touch the flooring when I put them in or out. We have a 2005 Georgie Boy Landau.
steveownby
Cosby, TN
Posted: 02/12/12 05:47pm Link  |  Print  |  Notify Moderator
You put the slide slickers down just before pulling the slides in and pick them up as soon as the slides are back out. We use 4 slickers on a 16' slide. All 4 are easy to stow as all 4 stacked together are about an inch thick.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
mac51
Western Pa.
Posted: 02/13/12 04:53pm Link  |  Print  |  Notify Moderator
Thanks everyone for all the variables in flooring. We have decided on a combination that fits what we want to acheive from all your differant products used that worked for everyone. We will have this done by the end of March (hopefully)as the temp warms up a bit consistantly. I will try to post some pictures of the finished project soon after. Thank you Mac
2002 HR Vacationer 32pbd Ford V-10
Davis Tru-Trac/Bilsteins
Henderson rear trac bar
2011 Cruze
 > Flooring change
