RV.Net Open Roads Forum: Dinghy Towing: Has to be level?
Search only in Dinghy Towing
 > Has to be level?
loydt
Cornelius, NC, USA
Posted: 02/10/12 09:50am Link  |  Print  |  Notify Moderator
My Ford Ranger is just a tad bit higher than the back of my coach when hooked up to my Blue Ox tow bar. Its not bad, but just a little bit. Im thinking that should be fine?
2006 Monaco Camelot 40PDQ, Cummins 400 ISL, 2012 Itasca Ellipse 42QD, Cummins 450
VintageRacer
Tatamagouche Nova Scotia
Posted: 02/10/12 09:54am Link  |  Print  |  Notify Moderator
It's hard to define "tad". One man's tad may be another man's 3".
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
Two Hands
California's Central Coast
Posted: 02/10/12 10:14am Link  |  Print  |  Notify Moderator
I recall a four inch rule. Check out the Blue Ox web site and/or your Blue Ox owners manual.
2015 Fleetwood Excursion 33D
2013 Ford Edge
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
phillyg
SWFL
Posted: 02/10/12 10:32am Link  |  Print  |  Notify Moderator
If you mean your tow bar is not level because of the difference in height from the receiver to tow vehicle connections, each mfgr provides its own specs for how far out of level the bar can be. Go on their website and you should find the spec for your bar.
2014 Forest River Wildcat FW 327CK; 2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear. Retired and enjoying life
RJsfishin
Winston Or.
Posted: 02/19/12 06:00am Link  |  Print  |  Notify Moderator
I don't know why the MFGs spec would differ. It has nothing to do w/ the TB IMO.
A TB should never be running downhill for the chance of the toad climbing "up and over" in a panic stop situation. But of course the toad braking system would come into play there also.
Specs I found showed TB to be between level, and 2" max uphill. Makes sense to me. I would never run a TB downhill for obvious reasons. But,....I don't run toad brakes either.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 12v batts, ammeters, led voltmeters all over the place, KingDome/sat, 2 Oly Cat heaters, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
 > Has to be level?
© 2016 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
