RV.Net Open Roads Forum: 2006 Ford E450 Chassis - Oil Type and Filter?
 > 2006 Ford E450 Chassis - Oil Type and Filter?
rpgibbs
Estero Fl
Posted: 02/10/12 05:20pm Link  |  Print  |  Notify Moderator
We are picking up our new used motorhome, a 2007 Forest River Lexington 283TS GTS model next week and want to perform some minor maintenance before we go on our first trip. It is on a 2006 E450 Ford Chassis. I would like to know what type of oil is recommended (Viscosity, Synthetic blend or full Synthetic) and does anyone know the Motorcraft or Fram Oil Filter #? Thanks for any information.
Home Skillet
Pearland Texas
Posted: 02/10/12 06:34pm Link  |  Print  |  Notify Moderator
5w20 Synthetic blend oil is fine.
6qts oil.
Motorcraft FL820 oil filter.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
ScottMack
Oklahoma
Posted: 02/10/12 06:39pm Link  |  Print  |  Notify Moderator
Install a Fumoto valve (F-106 model fits the V10 triton) in place of the drain plug when you do your first oil change - It will make subsequent changes a piece of cake. I put one in ours and love it......
2010 Winnebago Outlook 29B
2010 Ford Escape (1 blown tranny at 4876 towing miles)
Mocoondo
Chicago, IL
Posted: 02/11/12 09:10am Link  |  Print  |  Notify Moderator
5W20 (although I prefer dyno) as the recommended oil.
PF 1250 is the AC Delco filter number, if you need that.
I personally use Pronto filters P04651 as they are a lot cheaper and of equally good construction as OEM. Roughly $1.75ea.
RambleOnNW
Pacific Northwest
Posted: 02/11/12 09:23am Link  |  Print  |  Notify Moderator
I use the Motorcraft FL820S oil filter and Mobil 1 full synthetic 5W-20 oil and change the oil once a year.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
hilldude
Red house WV
Posted: 02/11/12 11:45am Link  |  Print  |  Notify Moderator
I use Motorcraft 5w20.I don't have the Fumoto valve in the MH but have one on the car well worth the money.
W4MBG
Williamsburg, VA
Posted: 02/11/12 05:11pm Link  |  Print  |  Notify Moderator
same routine as vikrv. change the oil before winter storage to get the water and acids out.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
j-d
Sunny Florida USA
Posted: 02/11/12 05:31pm Link  |  Print  |  Notify Moderator
If you're used to changing oil and filters, you'll find the V10 easy. Since the filter is mounted vertical, it's easy to get any kind of wrench onto to remove it. But! The Oil Cooler Adapter is above the filter, so you get a lot more oil draining out once the filter is off than you might expect. Way more than you want to trap with newspaper. Some kind of pan for sure!
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
chrisjpr
Owosso
Posted: 02/11/12 08:00pm Link  |  Print  |  Notify Moderator
Mobil 1 baby!
ASPENMAN
New Mexico
Posted: 02/12/12 09:45am Link  |  Print  |  Notify Moderator
Ford E-450 6.8 10 cyl 2012. If the engine did not come with Mobile 1 synthetic oil can it just be introduced with the next oil change? OR is any flushing out required?
BLOGS:
http://rvpainter.blogspot.com
http://art4rvs.blogspot.com
31' Class C NEXUS Phantom 4/4/12
Pressure Pro TPMS
Progressive Industries EMS/Surge
WiFi Ranger Mobile
Cab over entertainment center
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
