RV.Net Open Roads Forum: staying put: adding permanent structure for wood heat?
 > staying put: adding permanent structure for wood heat?
retired-tech
flint mi
Posted: 02/11/12 03:18pm Link  |  Print  |  Notify Moderator
you could build the structure and then use seals for a garage door to seal the gap. just use screws to attach them. you will be able to remove them easily to remove the trailer.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
pkunk
Questa, NM
Posted: 02/11/12 09:29pm Link  |  Print  |  Notify Moderator
Probably more than you want to spend, but..... Dock seal
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
johnbhicks
Southeast
Posted: 02/11/12 10:12pm Link  |  Print  |  Notify Moderator
Before you get going check what county code is going to allow; I'm reasonably certain you can't attach the structure to the TT while a flexible seal such as foam crammed into the gap would be ok, especially after the building inspector has already signed off on the clearly not-attached structure.
-C&J-
www.fugawetribe.com
jetboater454
Camping or home
Posted: 02/12/12 05:42am Link  |  Print  |  Notify Moderator
Connection to the trailer is just insulation stuffed in the gap,then a trim board screwed in,door stays open or removed.They have some at Riverbend that you can not even see the trailer,and one guy that has a second level,2 bed,1 bath addition.Some even have 2 outside a/c units like on a regular house.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
creativeusername
North Georgia
Posted: 02/12/12 06:24am Link  |  Print  |  Notify Moderator
Retired-tech: Seals for a garage door. I like it, thanks!
pkunk: Commercial dock door would be great, like the airplane solution, but I've found if I have to request a quote I probably can't afford it.
johnbhicks: The land is in a place with no residential zoning. No permits, no inspections. One of the few remaining places in this land where property rights are still respected.
jetboater: Trimboard, yes! That was the missing piece to my gap stuffing idea. Thanks!
johnbhicks
Southeast
Posted: 02/12/12 09:36am Link  |  Print  |  Notify Moderator
That's great! White County in northeast Georgia's become too civilized; these days you practically have to have a permit to dig a hole with a shovel.
Somewhere along the way I was told that the reason a structure was not permitted to be attached was that a TT or park model has no wind rating.
pkunk
Questa, NM
Posted: 02/12/12 10:05am Link  |  Print  |  Notify Moderator
Try and find a long inflatable balloon ( or several). Use it like the dock idea.
Tek-Rep
Haskell,TX USA
Posted: 02/15/12 04:52pm Link  |  Print  |  Notify Moderator
Cut the bottom out of an inflatable boat. Air it up to fill the gap.
