RV.Net Open Roads Forum: Tech Issues: another 'roll up' solar panel ?
 > another 'roll up' solar panel ?
pkunk
Questa, NM
Posted: 02/11/12 02:58pm Link  |  Print  |  Notify Moderator
These panels from ebay are a real good deal and I'd like to be able to use them but....I only have 15'6" of straight line on the roof and they are 16'5". Can they be cut? I realize the watts & volts would be diminished a little.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
jauguston
Bellingham, WA
Posted: 02/11/12 03:41pm Link  |  Print  |  Notify Moderator
A solar panel that takes that much space for a supposed 124w output is a joke.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
MrWizard
Traveling
Posted: 02/11/12 05:31pm Link  |  Print  |  Notify Moderator
i don't know about cutting, but plan on a good mppt controller
those panels are 42voc 30vimp
http://www.dcpower-systems.com/product_detail.aspx?gid=9&pid=22759
124 Watt Solar Laminate (PVL-124)
Features
Virtually unbreakable due to no glass
Encapsulated in UV-stabilized polymers, includes EVA and the fluoropolymer ETFE
Easy peel & stick application with microbial inhibitor
Bypass diodes are connected across each cell
Shadow & high heat tolerant
High temperature and low light performance
Quick-connect terminals
Electrical Characteristics
Rated Power (Wp): 124W
Open Circuit Voltage (Voc): 42V
Maximum Power Voltage (Vpm): 30V
Short Circuit Current (Isc): 5.1A
Maximum Power Current (Ipm): 4.1A
Specifications subject to change without notice.
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
MrWizard
Traveling
Posted: 02/11/12 05:38pm Link  |  Print  |  Notify Moderator
Jim
Unisolar does use more sq inches of roof space per watt generated
they are also lighter, work over a larger spectrum of light, and very hard to damage,
you can not crack them or get water leaks from weather, hail, or being stepped on, they are shade tolerant, with bypass diodes on each cell,
partial shading does not stop them from producing power
the 64 & 68 watt panels are ideally suited for parallel operation and can be used with a PWM controller iF so desired
pkunk
Questa, NM
Posted: 02/11/12 05:47pm Link  |  Print  |  Notify Moderator
I didn't intend for this to be an argumentative discussion on whether these were good (your definition) solar panels or what kind of controller to use. To me, they are a good buy. I only wish to know if they can be trimmed to fit. If so, I can squeeze alot of watts flat on my roof which is what I want to do.
MrWizard wrote:
Jim
mena661
Posted: 02/11/12 06:18pm Link  |  Print  |  Notify Moderator
No you can't trim them.
Trojan L16 6V's 740 Amp-hours
camperpaul
Wherever I park my travel trailer
Posted: 02/11/12 06:20pm Link  |  Print  |  Notify Moderator
NO!
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
pkunk
Questa, NM
Posted: 02/11/12 07:21pm Link  |  Print  |  Notify Moderator
OK, thanks. I guess I'll have to wait until a size I can use goes on sale.
MrWizard
Traveling
Posted: 02/11/12 07:49pm Link  |  Print  |  Notify Moderator
The 68w panels are 12.5 ft long
Can be found listing for around $160
Yes thats more per watt than the 124w panels
These panels are on close out. Thats why the reduced prices
Unisolar has switched to larger panels for grid tie
I have two of the 68w panels on order thru a local dealer for $150 each
Due to arrive in six days
landyacht318
Near a large body of water
Posted: 02/12/12 12:00am Link  |  Print  |  Notify Moderator
You sure on that 12.5 foot figure?
The discontinued unisolar 68 watter I'm looking at is 122 inches, 9.3 feet.
I ordered one. If it is 12.5 feet, I'm sending it back.
