RV.Net Open Roads Forum: Tech Issues: 31C Winnebago Slide Out Problem
 > 31C Winnebago Slide Out Problem
DelCamper
Delaware
Posted: 02/11/12 03:48pm Link  |  Print  |  Notify Moderator
Our 2011 31C Winnebago slide out closes 2" and stops. We get a fault code. Ran engine at same time so no low voltage issue.
How do you overide it? Have insufficient manuals. Does anyone have access to the codes to tell me what is wrong? I read if I push the open and closed buttons at the same time it over rides the system.
Any help is appreciated. We WERE going to Orlando Monday......
pulsar
Lewisville, NC
Posted: 02/11/12 04:10pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
1995brave
San Antonio, TX
Posted: 02/11/12 05:47pm Link  |  Print  |  Notify Moderator
Maybe you canfind some answers here.
DelCamper
Delaware
Posted: 02/11/12 06:26pm Link  |  Print  |  Notify Moderator
1995 brave
Thanks but been there, no use. What I need is the fault code list (how many Red & Green light flashes and what they mean) on the slide out control panel allowing me to know what is stopping the movement after 2". I'm chasing my tail with this by being referred to a low voltage code only on the internet. That's not the code I have (kinda like I have SOS in Morris Code and I get referred to ABC). Unfortunately I do not have the slide out manual buying this 2011 Class C Winnebago used.
I'm somewhat concerned that this has only 5000 miles and is only a year old. Is the problem systemic? Did the last person trade it in because it was a lemon in this regard? Kinda frightened about this. I feel like a kid with a broken toy on Christmas Morning.
Thanks again for your help.
CloudDriver
New Jersey Shore
Posted: 02/11/12 09:18pm Link  |  Print  |  Notify Moderator
Our 2003 Minnie has the Kwikee DigiSync system to control the slide. The slide is moved by two electric motor driven acme screws. I don't know whether Winnebago used this system on your newer model MH. I do have the Operation Manual and the Service Training documents for my slide and they list the error codes.
If you would like a copy of these, please PM me with your email address. I will scan the pages and forward them to you as email attachments.
Also, it would be a good idea to contact Winnebago's Service Administration and ask them for copies of the documentation that they provided when your MH was new. They will want the Winnebago Serial Number, which is located on the driver's door frame. You should also register your MH as a second owner so they can more easily provide info.
Winnebago's contact info and link to registration can be found here.
2003 Winnebago Minnie 24F - Ford E-450
