RV.Net Open Roads Forum: Towing: Lack of clearance on Reese Dual Cam
Search only in Towing
Open Roads Forum  >  Towing
 > Lack of clearance on Reese Dual Cam
kpratte
Southern NH
Posted: 02/12/12 10:05am Link  |  Print  |  Notify Moderator
So in a nutshell here is my problem, under tight turns the WD bars hit the cam arm above the nut. Here is what the cam arm looks like:
On my previous camper my setup looked like this and I had no issues:
When they setup the camper they left only two rings hanging free, seven between snap up and cam. When I hitched up with the 1200lb bars, I noticed that it was easier than with my previous camper with 800lb bars and 3 free rings. I then changed the current camper setup to 3 free rings and it was much heavier than the 800lb bars.
I checked the installation instructions and they say that the pivot point for the cam arm should be 18" back from the hitch ball socket. Mine is pretty close, maybe 18, 18.5.
So, short of moving the cam arm attachment forward 2", anybody got an idea why there is such a huge difference? And any ideas on how to fix?
- Ken
2010 Toyota Tundra 5.7 CrewMax Limited, TRD Swaybar, Timbrens, Bilstein HD shocks
2012 Keystone Sprinter 272BHS
Reese DC Sway, Fastway Flip, Tekonsha P3
Yamaha 2400iSHC Generator
skipnchar
Topeka or somewhere else
Posted: 02/12/12 10:15am Link  |  Print  |  Notify Moderator
Is the tow vehicle and trailer EVEN when hitched up or is the tongue a little on the high side? Might lower the hitchhead slightly to create more clearance, then compensate by applying more spring bar pressure (tilting to the rear). From the photos it APPEARS that it would only happen when reversing so simply not turning as sharply may be the solution if that's the case.
Good luck / Skip
tomman58
Southeast Michigan
Posted: 02/12/12 10:21am Link  |  Print  |  Notify Moderator
I seem to always carry the wet blanket but .............. Take your unit to the dealer of choice and let them be the guiding light on this issue. There have been several times on this site that much info is given on this kind of issue but some is good and some very bad. Everyone tries to help but on something as important as this from a towing point and a turning point go to the experts!
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
alageezer
seale, al
Posted: 02/12/12 10:23am Link  |  Print  |  Notify Moderator
What I see is the difference in the frame sizes. You may have to readjust your hitch head angle to get the clearance you need.
From what little I know, a top mounted hitch on a large frame usually dictates the use of round bar setup rather than the trunnion type it looks like you have.
2011 Bounder Classic
downtheroad
Pacific Northwest
Posted: 02/12/12 10:39am Link  |  Print  |  Notify Moderator
Can you post a pick with the trunion bars in (all hooked up and trip ready).
From the pic above, I can't get a clear idea of what is going on.
Also, if appears that you have the whole set up bolted too far forward.??
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
SuperDutyFiver
Long Valley, NJ, USA
Posted: 02/12/12 10:59am Link  |  Print  |  Notify Moderator
Without a few more photos the one observation I make is that your new frame is taller than the old one-which will definitely change the geometry of the bars to hitch and angle(meaning you'd have to move the mounts back some to maintain the proper angles-or tilt the head back more-I think)-have you considered this?
1 PSD 4x4 Custom Tow Vehicle-the 550
1 PSD 4x4 SUV-the X
2 PSD 4x4 Duellies-F350&F250HD
36' Carriage Carri-Lite
32' Open Triaxle Dovetail
22' Gooseneck Dump
E450 PSD 4x2 Chassis Cab
E550 PSD 4x2 Cube Van-The Beast
RIP-Prowler 345Y LSI-THANKS SUPERSTORM SANDY...
ScottG
Bothell Wa.
Posted: 02/12/12 11:30am Link  |  Print  |  Notify Moderator
You know, this is what I was thinking too when I saw the pic. It really looks like the assembly is too close to the ball.
Scott, Grace and Wesly
H0NDA eu2000i
TURK2500
SE Michigan
Posted: 02/12/12 11:57am Link  |  Print  |  Notify Moderator
Ken,
Sounds like you need a fresh set-up/adjustment, and/or fine tuning...., and keep in mind even a minor adjustment at the WDH/DC may impact the weight distribution between the TV & TT.
In some cases where the TT ball coupler is welded to the top of the A-frame in conjunction with a wide TT frame interferences can be an issue, but in most cases there are solutions.
To give you a detailed walk through in adjusting the Reese HP Dual Cam (and interference solutions), please refer to the the lower portion of this Towing forum sticky for some guidance: Reese HP Dual Cam Install/Adjustment
If the information in the 'sticky' falls short of addressing your problem, please post back. Also, if you have a pic of your new TV/TT combination hitched-up, that would be helpful to.
Bob
02 Chevy, 2500HD/4x4, 6.0L/4:10, GVWR 9,200lbs., GCWR 16,000lbs.
05 Jayco Eagle, 278FBS, GVWR 9,000lbs.
TV/TT loaded: 14,700lbs.
Loaded Tongue Weight: 1,250lbs.
Loaded TT weight: 8,400
Putnam XDR Class V, Reese HP Dual Cam.
301TBS
Ontario, Canada
Posted: 02/12/12 12:00pm Link  |  Print  |  Notify Moderator
Go online and download a manual. Follow steps carefully for ball height, ball angle, bar angle etc. It is very critical. Don't trust that it was done properly.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
Bob/Olallawa
Kitsap Co, WA
Posted: 02/12/12 12:22pm Link  |  Print  |  Notify Moderator
I think if he tries to move it any more to the rear he will run out of threads for the rear nut. Proper position would have the inside nut close to center of threaded shaft not one end or the other and the round carrier end for the bar has to end up in the same place so if he moved it toward the rear any more the the shaft would be moving into the coupler not away from it. Head tilt to the rear and maybe a raised ball will help with the clearance. If his tongue weight is more than the bar rating he needs to get heavier bars. I fought the same problem, went to 1500 lb bars, tilted the head as far back as I could and put on a raised ball. Problem solved.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
