RV.Net Open Roads Forum: Flat screen TV without HD Sat Dish,is it worth it?
 > Flat screen TV without HD Sat Dish,is it worth it?
Page of 5
rvrepairnut
bc
Posted: 02/13/12 05:54pm Link  |  Print  |  Notify Moderator
peaches&cream wrote:
rvrepairnut wrote:
Johno02 wrote:
HDMI cable is the little flat connector with the EXPENSIVE wire between the ends. For the rich purist, it is absolutely the best way to go. For the rest of us, considering the usually less than great signals we get in the RV, Coax works fine. Next best is 3-plug AV cable. We get really good HD using standard(new) batwing and pre-installed coax cable. If it ain't broke, dont try to fix it!! Still say the new flatscreen was well worth it. 130' lighter in the frontend, better handling, better mileage..
Also remember u can only receive free to air(antenna) HD TV if your your HD TV contains a HD tuner.If it does not then you wont receive the broadcast in HD.Just because your TV says HD does not mean it contains the required tuner
Ok, you are saying a HD tv may not be able to receive HD tv. then what does it receive?
A HD TV receive,s regular 480i digital programming unless you have a
HD receiver converter or if you have a HD with built in tuner then U can receive free broadcast HD TV.HOWEVER if the HD signal is scrambled from TW etc then u still need a TW receiver converter no matter if u have the tuner.IN other words all the Free over the air and or unencrypted Cable HD programming can only be viewed with a HD TV and only if you have a built in tuner.
(EG) I have a HD plasma TV but no built in tuner so I rent one from time warner for 10$ PM so I can watch all HD programming.IF I go boon docking and watch TV through my HD capable rooftop antenna I cant view in HD because I dont have a built in tuner
if you have a (ATSC/Clear QAM) option on your TV you can receive
NON scrambled HD channels through regular cable such as ABC
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 02/13/12 10:20pm Link  |  Print  |  Notify Moderator
imgoin4it wrote:
Sat Dish = SD
Thanks, I learned something today!
SCVJeff
Santa Clarita, CA.
Posted: 02/14/12 01:29am Link  |  Print  |  Notify Moderator
An HD monitor is not an HD receiver.. two different things. "HD" monitors have been around for any years but did not have either an ATSC HD receiver, or any receiver at all.. in order to display 720 or 1080 HD streams, you needed to feed it either component, HDMI, or HD-SDI.. They did not have receivers in them. That has now changed..
Jeff - WA6EQU
The Texan
Meridian, Idaho
Posted: 02/14/12 06:52am Link  |  Print  |  Notify Moderator
J-Rooster wrote:
imgoin4it wrote:
Sat Dish = SD
Depends on how it it used....in this discussion, SD stands for "Standard Definition" TV and HD stands for "High Definition" TV.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
vcallaway
On the road.
Posted: 02/14/12 07:03am Link  |  Print  |  Notify Moderator
Another thing to add. There is absolutely no difference between an $80 HDMI cable and an $8 HDMI cable.
1989 Honey Maxum
SoakedKarma
Reno neh-va-duh
Posted: 02/14/12 09:52pm Link  |  Print  |  Notify Moderator
I get 5 1080p HD channels and 12 480p channels off air from my 24 year old Wineguard Bat-Wing antenna locally... Sooo the answer is yes upgrade to HD flat screen and you won't need satellite dish HD for network broadcasts..
1989 38' Elite by Elite Coach Corp.
Ford 460cid C6 w/Gear Vendors Under/Overdrive 2 speed-transmission
208" WB John Deere RV 1200 Chassis air bag tag axle.
21,000 GVW
1987 Honda cmx250c Rebel
rvrepairnut
bc
Posted: 02/14/12 10:24pm Link  |  Print  |  Notify Moderator
No Upgrade to HD TV with a tuner.NOT all HD Tv,s have this option
SCVJeff
Santa Clarita, CA.
Posted: 02/15/12 02:07am Link  |  Print  |  Notify Moderator
Well.... almost... Depends on how it's being sold. The better long run cables use purpose built low-cap cable, and it'll probably say so (that's how you keep the data rates from collapsing on long runs). The others wouldn't know what the word meant.
Johno02
Lexington, TN USA
Posted: 02/15/12 12:31pm Link  |  Print  |  Notify Moderator
I know that it shouldn't, but my batwing antenna into good coax gives excellent HD reception off the air. Using a Visio HD LED digital TV, 1080p, 120Hz refresh. Winegard Sensar IV. Rear analog TV has no HD, analog with converter. lousy picture, but I don't watch it much anyway. The HD on the main TV from Coax easily matches what we have at home from cable HD with all HDMI connections.
Noel and Betty Johnson
2005 GulfStream Ultra Supreme, 1 wife, 1 Poodle
vcallaway
On the road.
Posted: 02/15/12 05:02pm Link  |  Print  |  Notify Moderator
We have found that over the air broadcast HD is better quality than the HD from Dishnetwork.
Page of 5
