ClassAGeek
NYS
Matt_Colie wrote: Get a can of 3M 77. 10$/can I use it to put the fabric/pleather etc back in the boats I work on. Epoxy does not do well with leather.
Matt
My father did 'auto trim' work for over 40 years. I did this type of job with him literally hundreds of times. 3M 77 contact cement, Permatex upholstery adhesive, or generically named 'headliner adhesive', is the right product.
Happy Ford F-53 Class A Owner (2008 Gulf Stream)
2010 Ford Fusion Toad (with 6 speed manual transmission - the only way to tow)
Brake Buddy Vantage, Blue Ox Aladdin Tow Bar,
TST RV 507 TPMS, Power Master Voltage Controller
dirtyharryo
United States
Goop is one of, if not the best glue on the market, I have used it for everything including shoe soles, a tube of that should do the trick for you. Report back on what glue you used and how it worked.
cwenger
Arnold, MD
Thanks to everyone who answered my post.
My brother was in the auto body repair business, and he offered to help when we get together in March. So, I think I'll wait untill then to tackle the job. I know that he has used some of the products suggested in the replies to my post.
Carl
ClassAGeek
NYS
I love GOOP and use it all the time. Great to have on any RV trip,
Just beware. GOOP has limited ability to hold hard plastic and fiberglass. Its shear strength is particularly low because it has to be applied relatively thick. I guess that's another reason I like it. You can remove GOOP without using a solvent. Just rub and you are able remove all traces from hard surfaces.
3M 77 and its preferred commercial cousin 3M 38008 Headliner Adhesive is more tenacious and permanent. Once dry, you cannot remove with friction alone.
bill h
coastal reconquista
Another fan of Shoe Goo and Goop. Pretty much the same product from the same company.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
Sully2
Cincinnati
wildmanbaker wrote: Use contact cement on both surfaces.
Most definitely!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
rssnape
Southeast
One thought is that the backing material may be coming off of the dash material, so no adhesive will work unless you bond to the top layer as well.
1997 Tiffen Allegro Bus
8 L Caterpillar
doc brown
Redondo Beach, CA,
Had the same problem. I used 3M double sided industrial tape - gray material with the red covering. I use that on many things in the rig. For example, I installed crown molding in my rig with this tape because I did not want to use nails. I love this stuff.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
Your Old Dog
Western New York
sch911 wrote: wildmanbaker wrote: Use contact cement on both surfaces.
Yup.... Apply to both sides, and let dry to tacky. Then press together for a permanent bond.
This stuff is made for high temp automotive use where temps can go up to 140-150 in a car interior. You can get it at NAPA auto parts, about $14.00 but works great.
Unless tomorrow has been promised to you, you better get busy today.
RetiredBob
Portage, MI
A good site to use for any "How do I stick X to Y?" question is ThisToThat
