RV.Net Open Roads Forum: Class A Motorhomes: Motor Aid on New Winnebago
 > Motor Aid on New Winnebago
ct1978barnes
Bryan Ohio USA
Posted: 02/12/12 06:53pm Link  |  Print  |  Notify Moderator
Do you have to have the front heater on and heat seating in the red to get the rear heater to blow hot air in back. It dose not say much about it in the Winnebago book.
Charles Barnes
2chiefsRus
USA Somewhere
Posted: 02/12/12 07:28pm Link  |  Print  |  Notify Moderator
If I'm understanding your question correctly, we have two furnaces and there are two zones on the thermostat - one for the front furnace/heat pump and zone two for the rear furnace/heat pump. Do you have one thermostat or two?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
YC 1
Yuba City Calif.
Posted: 02/12/12 07:31pm Link  |  Print  |  Notify Moderator
Motoraid on my Winnebago was the engine heating the hot water heater while driving. As far as the rear heat I did not have to turn anything on up front except a switch for the rear fan.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
Cat320
Somewhere in the USA
If you are using a heat pump...they don't work when it cold, around 45 and below.
cm
Dillon, CO USA
Posted: 02/12/12 07:48pm Link  |  Print  |  Notify Moderator
Motor Aide is not a second furnace and it is not a heat pump.
To supply heat to the rear of the coach it is a auxiliary heater that runs off engine coolant. It is the same type of rear heater that you find in buses like a school bus or a airport shuttle bus.
Goldencrazy
madison wi
Posted: 02/12/12 08:31pm Link  |  Print  |  Notify Moderator
Some do have the rear heaters however motoraide is the automatic heating of hot water while engine is running. Two hours on the road and the water will be very hot. Great feature. I often take off in the morning if boondocking and stop and shower after driving for a couple of hours. Hot water, no charge.
Golden_HVAC
Fulltime, CA, USA
Posted: 02/12/12 10:03pm Link  |  Print  |  Notify Moderator
Hi,
I agree that Motor Aid from the factory is only to heat the hot water heater.
Yet who knows what a prior owner installed in your coach? If you do have a fan coil, with water tubing that gets hot while driving, then you only need to find the fan switch, and turn it on on cold days. There might be a valve under the hood that controls water volume to the heater core, or not? Or the valve might be near the heater unit.
Fred.
ct78barnes
Bryan Ohio USA
Posted: 02/13/12 04:08am Link  |  Print  |  Notify Moderator
Thanks every one for the help . It is a brand new coach and it has black hoses that go around the water heater and the same under the bed so the hoses go back under the bed for some reason. It is a Winnebago Sightseer 35J 2011.It also has a fan switch in front that says rear heater that lights up green when on and has a low and high setting. What I am asking is front on the car heater dose it have to be in vent or heat mode for the rear heater under the bed to work. I turned it on our last trip and the wife went back and it was blowing cold air .
marvh
Tampa area
Posted: 02/13/12 05:11am Link  |  Print  |  Notify Moderator
Why don't you call Winnebago? Marvh
Lt46
Central Florida
Posted: 02/13/12 06:52am Link  |  Print  |  Notify Moderator
On my older Winnie, if the engine is running, coolant is circulating through the motoraid system. That is, from radiator to water heater to rear bedroom heater,back to radiator. The only "control" I have is a dash fan switch for bedroom heater. In other words; in the middle of July tooling down the highway my water heater is heating and my bedroom heater is hot. It's all or nothing.
Might be that newer models have a 1/4 turn water valve, or bypass in place somewhere to close off the rear heater option for summer months? I don't know but a call to Winnie might get you some answers
Peter & Dawn
97 Winnebago Adventurer 37RW
96 Prowler 27X SOLD
IAFF L-792
