RV.Net Open Roads Forum: Towing: WD hitches and unibody
Search only in Towing
Open Roads Forum  >  Towing
 > WD hitches and unibody
gmw photos
midwest
Posted: 02/13/12 07:08am Link  |  Print  |  Notify Moderator
How many folks use weight distribution hitches with their unibody tow vehicle ? Anybody have any specific experience that was bad using this combo ?
george
carringb
Corvallis, OR
Posted: 02/13/12 07:55am Link  |  Print  |  Notify Moderator
Ford requires using weight distribution on their Unibody vehicles (Flex, Explorer) to achieve the full tow rating.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
mkirsch
Rochester, NY
Posted: 02/13/12 08:58am Link  |  Print  |  Notify Moderator
If you stay within the manufacturer's ratings, there is no reason to worry about it.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
gijoecam
Midwest
Posted: 02/13/12 08:44am Link  |  Print  |  Notify Moderator
Provided the vehicle was designed and tested with weight distribution in mind, I wouldn't anticipate any issues. If, however, you're looking at adding a WDH to a vehicle not rated for one, I would not expect it to be long for this world.
red31
Bryan
Posted: 02/13/12 10:26am Link  |  Print  |  Notify Moderator
One minivan maker (dodge) required 'em!
A load equalizing hitch is recommended for loaded trailer weights above 1,000 lbs (454 kg) and required for weights above 2,000 lbs (907 kg). (2004)
Later manuals suggested
"Trailer sway control and a weight distributing (load equalizing) hitch are recommended for heavier tongue weights (TW), and may be required depending on vehicle and trailer configuration/loading to comply with gross axle weight rating (GAWR) requirements.
skipnchar
Topeka or somewhere else
Posted: 02/13/12 09:41am Link  |  Print  |  Notify Moderator
I would check with the vehicle manufacturer before installing one. SOME unibody vehicles will not stand the forces applied by a WD system and others limit the amount of pressure they can handle. They SHOULD be able to tell you the details about using them.
Slowmover
Corpus Christi, Texas
Posted: 02/21/12 09:05pm Link  |  Print  |  Notify Moderator
george
Seeing as how Dodge and Plymouth sedans & wagons were the tow vehicle of choice for much of the 1960's and '70's -- and unibodies, every one of them -- the history of WDH and unibody has depth & breadth. Done right, unibody is stronger than body-on-frame.
It would probably help to be specific about the vehicle being considered. Here, or elsewhere, someone already has experience with it.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 15-cpm solo, 25-cpm towing
BenK
SF BayArea
Posted: 02/21/12 09:16pm Link  |  Print  |  Notify Moderator
I'm not a fan of any WD hitch system on monocoque (unibody) vehicles. Yes there
are a couple (same, but just different badging...VW and Porsche)
Here is an old thread on the topic with some images of various labels and glove
box manuals
Towing a slingshot GT21FD with a Honda mini van
Bore down far enough and you will find reference to a Honda Pilot, which is
derived from a Honda Odyssey mini van
Here is the link to the manual series : Honda manual towing section
Where it specifically states WD not recommended
They only mention handling, but I say the real reason is that the monocoque
can't transmit the WD forces through the spot welded together body sections.
Bought my 2000 Odyssey used and it came with a U-Haul receiver (1.25
square pin box)
Even with just my bicycle rack, it flexes much more than I'm comfortable
with and consider that approx 150-200 lbs more than any tongue weight
I'd like to tow
-Ben Picture of my rig
BenK
SF BayArea
Posted: 02/21/12 09:28pm Link  |  Print  |  Notify Moderator
To be fair, just went and checked my Odyssey's glove box manual that I've captured
on my Internet photo account.
It does say okay to use a WD hitch, but elsewhere it limits the weight of the
max trailer factored by the passenger loading
Here they are:
MTWR factored by passenger loading
GCWR
WD hitch
U-Haul receiver label
whisperide
Golden Spike area
Posted: 02/22/12 05:46pm Link  |  Print  |  Notify Moderator
Kinda what I thought. I'm doing a custom hitch to spread the stresses out more, along more of the rear sub-frame rails. I'm not going WD, however. Instead, I'm upgrading the rear suspension. But I'm playing with a RWD unit-body car that was built with a solid rear axle. And even so, I'm adding a full roll-cage ( custom-revised ) with my sub-frame connectors to keep the car from becoming a giant metal banana.
How far you want to go is up to you, but as Stephen Tyler said; anything worth doing is worth overdoing.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
