Mark and Linda
Smyrna, Tennessee
This is a good post...my DW was asking the other day how long our 6 Gal. hot water heater will last. I am ex Vietnam Vet, so I know what a cold shower is. I am usually in and out. We just moved up from a PUP with no shower so anything is a blessing. I will be sure to use both the propane and electric when we are ready.
Ken O
Lake City, MI/ Winter in AZ and FL
The 6 gal heaters run much hotter than your house one, so less hot water is mixed with the cold. I can't see how you would run out, but I take Navy showers also.
Silverado 250HD '07 Duramax
'12 Jayco JayFlight 19RD
Old-Biscuit
Across the USA
Don't know what brand water heater you have........
If Atwood, swapping out a 6 gallon for 10 does require a bigger opening in side of rig and a deeper area to slide heater into.
Atwood 6 gallon......16"W x 12.5"H x 18"D
Atwood 10 gallon.....16"W x 15.5"H x 20.8"D
Swapping out an Atwood 6 gallon for an XT model (uses a mixing valve on back of heater=9 gallons) would be easier...same size opening just need 19.5"D
BUT there have been problems with the mixing valve units.......mixing valve malfunctioning so do some research if you are thinking about a swap.
Otherwise......conserve hot water use and use gas/electric for faster recovery
jerem0621
Sequatchie, TN
my propane only 6 gallon water heater has no problem keeping up with the four of us.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
lpxguy
Chalfont PA
how about this
2005 GMC Sierra 3500 CC DRW D/A
2013 Crusader 335BHS
edatlanta
Panama City Beach, FL
The tankless option would be fine except for those that spend a lot of time as hosts or other volunteers where electric is provided. When I am hosting I only use propane for cooking and that isn't much.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
the_happiestcamper
Mount Pleasant, SC
lpxguy wrote: how about this
From that website: "the temperature of the hot water coming out of the hot water faucet is determined by how open or closed the hot water faucet is; the faster the flow, the cooler the water; the slower the flow, the hotter the water. By adjusting the flow, RV’ers can literally have endless hot water!"
So, if you run the water too fast, it will be colder. Something tells me the OP wants a fast flowing shower with lots of hot water - otherwise, they would have figured out to do Navy showers.
Jon, Freesi, Lars, Tucker, Holland
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
broncojim34786
florida
These things should be standard issue on all RV's. Just shows you RV manufacturer's are not in business to satisfy customers, only to make a Buck by buying bulk, cheap items that require lots of service calls to the dealer.
jetboater454
Camping or home
Always have electric hook ups? Get a 20 gallon 110V at HD or lowes,mount it under the sink.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
aquarious
Marion Indiana
Most of the time we go camping it is with six people, four of them women. We can all take showers, with a low flow head, by not dilly dallying. We do not do GI showers and do not run out of hot water. This does not include washing hair as this is another story completely. Ed
