JayandFay
Hoquiam
How can I increase the hot water capacity of my 32'Maxlite---it is now at 6gal-----without Major Mods ??
Please help Wife and I need a better shower
Thanx JayandFay
donn0128
Pronounced Ore-gun
Learn to take GI showers or spend a grand on a new water heater.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
M GO BLUE
Southgate, MI
Rinse, turn off, lather up, rinse off....done!
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Finally Fulltiming
Summer: NYS Finger Lakes; Winter: Someplace warm
Or stay at CG's with showers.
BTW - Most RV's of all types only have 6 gal. heaters.
kaydeejay
SE Michigan, USA
donn0128 wrote: Learn to take GI showers or spend a grand on a new water heater. You quoting Canadian prices Don?
A 10 gal DSI propane/electric water heater is $450 - $550 on this side of the border.
Try here for a couple of examples.
Assuming the OP is capable and there is room in his unit, replacement is NOT a really tough job.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
beemerphile1
I'm 57, I'm not a
Define "major". You can add a second water heater or replace yours with a larger one. Either choice involves plumbing and electrical work.
A modern RV water heater is designed to deliver more than its stated capacity. They have a very large burner which gives fast recovery. A six gallon water heater with a low flow shower head should give 8 - 9 gallons of hot water.
Are you sure the current water heater is working correctly?
- Soren Kierkegaard
Dksd392
Switch to an instant hot water heater and never run out...it is not cheap and uncontroled use will burn a lot more propane
Artemus Gordon
Redding California
Got an email this very morning from Camping World offering a portable, continuous "hot water heater"! Little over hundred dollars. Have to use it outside, but hey cheap fix and opportunity to become "one with nature" so to speak!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
TURBODOG1000
INDY
JayandFay, does your current water heater have a propane burner "and" a 120 volt element? If it does turn on both at the same time, this will make your hot water last longer. If it only has a propane burner a 120 electric heat element can be added, I think the brand name is "Hott Rod".
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
rovobay
Damascus, Oregon (Portland Suburb)
kaydeejay wrote: donn0128 wrote: Learn to take GI showers or spend a grand on a new water heater. You quoting Canadian prices Don?
X2^
easy enough for someone who is handy with basic tools
1999 Cameo by Carriage 26FLS bought in February 2012 (our first trailer)
TV is a 2005 Chevrolet Silverado 2500HD 4X4 Crew Cab Short Bed with a 6.6l Duramax and Allison Transmission
