RV.Net Open Roads Forum: Truck Campers: Generator problem Followup
 > Generator problem Followup
dack
Port Alberni,BC,Canada
Posted: 02/13/12 11:22pm Link  |  Print  |  Notify Moderator
Thx for the comments re my generator problem rquest. I spent today talking to shops to repair it or replace it. Repairs could be ~1200$ if I could find someone to do the work. One experianced fellow told me I had too much rust/salt (the generator I hope he was referring to)from the coast and winter use and he would not do the work as we would both be unhappy( he was alittle more graphic than that and had comments re the 3600 generac's reliability). And he was a generac licensed shop. So I'm now looking at replacement with a Onam. I can get the work done at a couple of places including Northwood but its expensive. Has anyone had this conversion done and are you happy with the result? How do find access to service the Onam?
old guy
Oregon (pronounced Or e gun)
Posted: 02/13/12 11:45pm Link  |  Print  |  Notify Moderator
have you tried Sears. they work on just about every thing
sundowners
suffolk UK
Posted: 02/14/12 02:22pm Link  |  Print  |  Notify Moderator
Hi
I understand your issue----we tried several times on our 'US road trip' to get our generac working but finished up bringing to England not working------------------Just by chance(well I was phoning around to get it repared) I spoke to a guy who used to work on development at generac at the time mine was developed, he reckons he knows everything about the 'older' models ????!!!!-----------------well he said they are sooo complicated that he is the only person in UK who MAY be able to fix it !!!!--------------------------------------------------I am looking for a boat enthusiast who wants a unique anchor !!!!!!!!!!!!
Nigel & Pamala----Spain
dack
Posted: 02/15/12 01:29pm Link  |  Print  |  Notify Moderator
Finally found a dealer who would check it out and good news as it was a problem in the start /stop switch on the motor. Back to a nice cozy bed with the elec. blanket. It was a usefull experiance though as I found out the genarac 3600 is no longer available and installing a Onam leaves you with service issues because of the limited space and required side acces. Hopefully the generac will be good for many more years!!
sundowners
suffolk UK
Posted: 02/15/12 05:46pm Link  |  Print  |  Notify Moderator
You lucky devil--------Wish mine was that easy/cheap-------------------I will still take it to THE MAN and get an estimate--or, at least a MAX price to spend on it-----------trouble is, I have got used to the space where the genny used to live !!!!!!it has made a REALLY usefull locker on our present 'road trip'--------------------I am not sure that the genny is more usefull !!!!!!!
Nigel & Pamala---Southern Spain
88lover
Posted: 02/16/12 03:20pm Link  |  Print  |  Notify Moderator
sundowners wrote:
Hi
I just swapped my Impact 36 out with another impact 36 I picked up cheap so I can work on mine with some time and not cut into my camper usage. I accidently broke the 15A circuit breaker and had a hard time finding one (Generac listed for $64.00 but i found the identical dual pole breaker from Blue Sky marine for $37. If you want to work on your generator, I have both the owners manual and the service manual in PDF form. You should have a knowledge of electrical circuits as this is a DC generaator and the DC current is changed to AC by a inverter which is located by Lance under the floor of the Dinette. DC current produced is 187 volts and can Kill. I did not find the service manual hard to follow....but then I had time to kill
sleepy
Oak Ridge,Tennessee
Posted: 02/16/12 04:37pm Link  |  Print  |  Notify Moderator
I have had my generac impac 36P since Thanks giving 2002... 931 nights on the road... many more day trips... we use it for 10 to 12 hours at a time... It has been faithful... the only problem, a starter motor. I'd find another befor I'd have any of the light weights out there.
I'm glad that you got it fixed.
I wash our Generac... hose it down... and take a leaf blower to dry it... works for me and the generator seems to like it.
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
Reelescape1
Charleston
Posted: 02/16/12 07:33pm Link  |  Print  |  Notify Moderator
88lover, can you post or link to the pdf's?? Thank you!
covered wagon
Posted: 02/17/12 06:09am Link  |  Print  |  Notify Moderator
I don't know for certain unless I experienced what you went thru, but, if I had a built in generator that went belly up and could not be fixed, I would remove it and get a portable honda in there.
big whitey
raleigh,nc
Posted: 02/17/12 12:01pm Link  |  Print  |  Notify Moderator
x2
